Poly 318 Alt brackets same as LA engines ? #1483488
08/12/13 08:21 PM
08/12/13 08:21 PM
Fort Morgan
1OFNONE Offline OP
Has been a member for quite a few years, so relax.
1OFNONE  Offline OP
Fort Morgan
I know the style of the brackets changed but do they interchange from a Poly to a LA engine ?
So the bartender says to the horse " Gee, Why the long face?"
Re: Poly 318 Alt brackets same as LA engines ? [Re: 1OFNONE] #1483489
08/12/13 08:25 PM
08/12/13 08:25 PM
Andrewh Online content
Andrewh  Online Content
pretty sure it will be the same 70 and back, vs the 70 and up style.
a/c vs non-ac etc... have to match up.
so round backs only.
since pretty much everything else bolts up, I can't imagine the alt brackets being different.
Re: Poly 318 Alt brackets same as LA engines ? [Re: Andrewh] #1483490
08/12/13 08:32 PM
08/12/13 08:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Obviously, the heads are different. So if the bracket bolts to the head, then no is probably the answer.
Don't be the exception.
Re: Poly 318 Alt brackets same as LA engines ? [Re: 1OFNONE] #1483491
08/12/13 08:57 PM
08/12/13 08:57 PM
Fort Morgan
1OFNONE Offline OP
1OFNONE  Offline OP
Fort Morgan
Very good. Im going to swap a Denso alt onto my fathers Poly 318 and was just making sure. Thanks guys.
Re: Poly 318 Alt brackets same as LA engines ? [Re: 1OFNONE] #1483492
08/12/13 09:19 PM
08/12/13 09:19 PM
The 65 poly 318 and LA 273 used the same alternator bracket, but had two sets of mounting holes, one for the 318 poly head, and the other for the 273 wedge head. The 1965 A/LA bracket will also bolt to a later 318/340/360 LA. But since the later LA brackets don't have both an A and LA bolt pattern, I wouldn't think they would work on the poly without modification.
Now whether a Denso alternator would work with a poly alternator bracket, if that's what you're asking, can't say.
Re: Poly 318 Alt brackets same as LA engines ? #1483493
08/12/13 11:33 PM
08/12/13 11:33 PM
I used the later model square back on my poly.
BUT to get it to work, I needed a longer swing arm.
the 10 dollar chrome GM style one with some spacers to kick it out far enough away from the block worked for me.
you can kind of make it out here.
