Electric fans #1482903
08/11/13 04:51 PM
08/11/13 04:51 PM
Illinois
Mopar_Ray Offline OP
Illinois
I have a Be Cool radiator with there electric fans. Cools great, but draw a lot of amps? Volt gauge is at 14.5 volts@ 1200 until I kick on the fans then drops to 10-12 volts. There wired on duel relays with circuit breakers to the cut-off switch. Any ideas?
Re: Electric fans [Re: Mopar_Ray] #1482904
08/11/13 05:56 PM
08/11/13 05:56 PM
Az
Crizila Offline
Crizila  Offline
Az
Lose one fan. Smaller alt pulley, Find an alt that has a faster amp curve.
Fastest 300
Re: Electric fans [Re: Crizila] #1482905
08/11/13 06:25 PM
08/11/13 06:25 PM
Illinois
Illinois
It's an east-cost mini alternator one wire, fits the DMI low mount bracket. Think I'm going to try disconnecting one of the fans & see if it stills cool enough.
Re: Electric fans [Re: Mopar_Ray] #1482906
08/11/13 06:44 PM
08/11/13 06:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like the alt doesnt put out a bunch of amps..
what is the output
Re: Electric fans [Re: Mopar_Ray] #1482907
08/11/13 06:50 PM
08/11/13 06:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You could hook up each fan on a separate thermo switch
so one turns on at X temp then if it gets hot enough
that the other turns on.. just need 2 thermo switches
that you can get at O'Rielys for $18 each
Re: Electric fans [Re: MR_P_BODY] #1482908
08/11/13 07:01 PM
08/11/13 07:01 PM
Illinois
Illinois
Re: Electric fans [Re: Mopar_Ray] #1482909
08/11/13 07:06 PM
08/11/13 07:06 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
120 Amp.
http://m.summitracing.com/parts/eca-2003
Next time you need one of those save some money and go to the parts store. Thats a GM CS130 alternator. I have one on my Barracuda and it works great with all of my stuff, one fan, water pump, fuel pump, lights, no problem. I spec'd a 92 buick for my application. It was like $115 with a lifetime warranty.
68 Barracuda Formula S 340
Re: Electric fans [Re: MR_P_BODY] #1482910
08/11/13 07:22 PM
08/11/13 07:22 PM
Illinois
Illinois
That's a great idea Mr P. I put a thermostatic switch in my CSR water pump before I sent parts to my engine builder. My water pump & fans are on a switch. Thought it might be a good idea in case I forgot to turn on switches. Now I have to figure out how to wire?
Re: Electric fans [Re: Bad340fish] #1482911
08/11/13 07:32 PM
08/11/13 07:32 PM
Illinois
Illinois
120 Amp.
That's a good idea, il'l keep in mind. I have bought a few parts to later find out there was a cheaper alternitave.
Re: Electric fans [Re: Mopar_Ray] #1482912
08/11/13 07:34 PM
08/11/13 07:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats pretty simple... open the wiring harness to the
fans and separate them... I run a relay for fans so
I use the thermo switch to trigger the relay
