2009 SRT 8 #1482736
08/11/13 12:14 PM
08/11/13 12:14 PM
StewartP Offline OP
Mopar Vintage Picture Guy
StewartP  Offline OP
Info please,
weight of engine oil ?
which produces more vacuum - WOT or coast down ?
reason I ask, there is a billet technology catch can, installed between the oil filler and the intake tube. It gets full very quickly, the guy says it is because of the 3:91 gear and lots of 3000 rpm.
Sounds goofy to me, but what do I know ?
Re: 2009 SRT 8 [Re: StewartP] #1482737
08/11/13 12:55 PM
08/11/13 12:55 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Moble 1 oil
0W-40
My vacume gauge shows most vacume under deceleration. At WOT its + 5 psi with the Procharger. But was 0 with out the boost.
Re: 2009 SRT 8 [Re: StewartP] #1482738
08/11/13 01:59 PM
08/11/13 01:59 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Info please,
Vacuum when the throttle is shut.
Re: 2009 SRT 8 [Re: BobR] #1482739
08/11/13 04:50 PM
08/11/13 04:50 PM
Park Forest, IL
slantzilla Offline
Happy Birthday slantzilla  Offline
Park Forest, IL
Sounds to me like he's got something else going on. Mine is identical to what you described (minus the catch can) and it hasn't lost a drop of oil in 5000 miles.
Re: 2009 SRT 8 [Re: slantzilla] #1482740
08/11/13 06:47 PM
08/11/13 06:47 PM
StewartP Offline OP
StewartP  Offline OP
I agree, but some people are just slow
I asked him if he had looked at a plug ?
I suspect some kinda leakage - but
Re: 2009 SRT 8 [Re: StewartP] #1482741
08/11/13 09:11 PM
08/11/13 09:11 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Maybe I'm way off in left field here.... but I "believe" the hose he's refering to runs from the oil fill to the air filter housing. This would be "upstream" of the throttle body so it would actually be getting "pull" at WOT... correct? Seems to me I saw one at work with an aftermarket restricted filter and the air inlet was full of oil. Engine found that the breather tube was a good alternative for air thus causeing it to pull excessive oil vapor. Also seems to me that they changed this design of later models.
Re: 2009 SRT 8 [Re: J_BODY] #1482742
08/12/13 09:28 AM
08/12/13 09:28 AM
StewartP Offline OP
StewartP  Offline OP
J Body -- after drawing a picture for myself, us old men are handicapped, I see what you are saying. But, why should there be that much oil vapor floating around. I had the same set up on my Aspen, and never saw much oil in the catch can, even after 17,000 miles. He is saying 1/2 full after 3,000
Re: 2009 SRT 8 [Re: StewartP] #1482743
08/12/13 10:05 AM
08/12/13 10:05 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
i believe its a pretty well known issue with the HEMIs, otherwise there would not be so many catch cans on the market.
68 Barracuda Formula S 340
Re: 2009 SRT 8 [Re: slantzilla] #1482744
08/12/13 12:43 PM
08/12/13 12:43 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
You might wanna install one
http://www.youtube.com/watch?v=KSg5l-Q_QL8
http://www.youtube.com/watch?v=bAmImsHmEGM
Re: 2009 SRT 8 [Re: SRT6776] #1482745
08/12/13 01:21 PM
08/12/13 01:21 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I pulled the intake off of a 2008 SRT8 that had 874 miles on it. I set it down on the ground TB flange down. When I got back the next morning, it was sitting in a significant puddle of oil.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 2009 SRT 8 [Re: AlexP] #1482746
08/12/13 05:02 PM
08/12/13 05:02 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I think they are really hit and miss on ones that use oil vs ones that don't. Clean the catch can, change your oil then check it in 1000 miles. See how much is in there. I had a catch can on mine but I took it off. 3oz of oil in 3-4k miles didn't seem like it was worth it to me. If I raced the car regularly maybe I would care more.
Wait until the car goes into limp mode in the fast lane of the freeway during rush hour because one of those catch can hoses has a pin hole leak in it. I'd rather burn some oil...
DAHIK
Re: 2009 SRT 8 [Re: ntstlgl1970] #1482747
08/12/13 07:39 PM
08/12/13 07:39 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
DAHIK
Ditto That!
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
