Re: clutch adjustment uncertainty
[Re: 68LAR]
#1480467
08/06/13 11:50 AM
08/06/13 11:50 AM
Posts: 1,083 SE PA
Yellow Fever
SE PA
[Re: r3dplanet]
#1480470
08/06/13 08:12 PM
08/06/13 08:12 PM
r3dplanet
Okay. I've spent most of the evening trying to sort this out. For those that asked, I do have all 10.5" bellhousing conversion parts from Brewer's. I have the z-bar, bellhousing pivot adapter plate, new clutch rod, etc. Disregard the bronze washer in these photos. I was just trying different sizes to see if I could expand the gap. I have the correct washer, nut, grommet.
The geometry looks like 90 degrees between the bellhousing and z-bar. But here's a couple of pics in case somebody sees something amiss.
[Re: r3dplanet]
#1480472
08/07/13 02:54 AM
08/07/13 02:54 AM
r3dplanet
I'm wondering about this article from Mopar Muscle: http://www.moparmusclemagazine.com/techa...dal_adjustment/I know it says that it's mostly for high speed shifting, but what it does is to provide more throw on the clutch fork. To my way of thinking, that's exactly what I need. Has any one done this? Other thoughts?
