62-65 o/s mirror elfixo tip #148
04/28/03 11:01 PM
04/28/03 11:01 PM
Anonymous OP
Anonymous OP
heres a tip for fixin the manual mirrors when they get loose,these are the 1s with the 2 stands,look close around the mirror,there is a snap ring,pop it out and take the glass out,tap the outer part with a hammer where the ball socket sits,1 per side,reinstall the glass and ring,bingo,works fine,i just did 10 of them that i had,takes a little time but worth the effort
Re: 62-65 o/s mirror elfixo tip #149
04/28/03 11:29 PM
04/28/03 11:29 PM
Anonymous OP
Anonymous OP
Re: 62-65 o/s mirror elfixo tip #150
04/29/03 12:00 AM
04/29/03 12:00 AM
Anonymous OP
Anonymous OP
ive wondered about doing that but never tried it. thanks.
Re: 62-65 o/s mirror elfixo tip #151
04/29/03 12:03 AM
04/29/03 12:03 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
THANKS! i`ll have to do that, i know mine are loose.
Re: 62-65 o/s mirror elfixo tip [Re: 65rbdodge] #152
04/29/03 09:41 AM
04/29/03 09:41 AM
Anonymous OP
Anonymous OP
i have another style mirror also,think its for a 66 model,has the same base and a different style head,no lockring,guess ill have to soak it in gas and see if it will come off,then fix it
