Re: SB water pumps with motor plate ?'s
[Re: AndyF]
#1479004
08/04/13 03:39 PM
08/04/13 03:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The new parts that I'm making now use captured O-rings. So the motor plate can come off without changing gaskets or scraping RTV.
Thats a nice feature Andy...both sides?
[Re: MR_P_BODY]
#1479005
08/04/13 04:12 PM
08/04/13 04:12 PM
Posts: 311 Colorado Springs, Colorado
Dartthunder340
I am using a factory water pump with a motor plate and run it with the Moroso belt driven setup. It will be a while before I can post pics, I am at work. I am also using gaskets but don't get a chance to race a whole lot right now. I think Pittsburghracer mentioned something about gaskets getting alot of abuse so it has me thinking about changing up at the end of the season. Also want to upgrade pumps to. Forabodiesonly has a CSI unit for sale if you are interested. Hi Mr.PBody!
Better get inside Ma. Looks like a storm's comin'.
[Re: Dartthunder340]
#1479006
08/04/13 05:09 PM
08/04/13 05:09 PM
MR_P_BODY
Hi Mr.PBody!
Hi
[Re: MR_P_BODY]
#1479007
08/04/13 06:46 PM
08/04/13 06:46 PM
Posts: 31,002 Oregon
AndyF
Yes, the parts that I'm making now will have O-rings on both the timing chain housing as well as the motor plate. So no gaskets are required.
[Re: AndyF]
#1479011
08/06/13 11:06 PM
08/06/13 11:06 PM
AndyF
No gaskets are needed for the water pump, or the motor plate.
[Re: AndyF]
#1479013
08/08/13 02:43 AM
08/08/13 02:43 AM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
[Re: Dos Snails]
#1479017
08/11/13 08:53 PM
08/11/13 08:53 PM
Posts: 51 San Diego, USA
SoCalRacer
San Diego, USA
Sorry, not a very good picture, but I ran this setup on my 340 for many years every weekend the track was open. Used paper gaskets both sides of the motor plate with a thin layer of RTV. It's a stick car launched at 7,000 RPM, so it's definitely applying some torque to the motor plate! No leaks or cooling problems ever.
If it ain't broke ... you're not pushing it hard enough.
[Re: SoCalRacer]
#1479018
08/12/13 11:08 AM
08/12/13 11:08 AM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Do you have a front pic of the stock WP install? I curious how you got the lower hose to fit. Jim
#1479021
08/18/13 08:06 PM
08/18/13 08:06 PM
rt66jim
Joplin, Mo
I can get you the part number from my hose if you would like.
Well I gave up on using my Clay Smith mech. fuel pump today. I was going to have to purchase an electric WP to use it. So I opted to use the WP set I already had. I will by an elec. FP. I'm thinking a Mallory 250. Anyone have a better pump for the money?
[Re: rt66jim]
#1479022
08/31/13 11:17 AM
08/31/13 11:17 AM
Dartthunder340
I have been happy with the Mallory pump(s) I have used. On another note, the gasket between the back of the plate and the timing chain cover lost itself last nite. Not too sure which direction to go just yet, I am leaning towards an electric.
