Re: WHO'S REAR BAND ON BB 727??
[Re: DusterW2]
#1478948
08/03/13 10:33 PM
08/03/13 10:33 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
if its not an aluminum drum a band from your local trans parts supplier will be fine, rear band is only on when in rev or it is holding in manual if the vb has low band apply.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Labratt]
#1478950
08/04/13 06:49 PM
08/04/13 06:49 PM
Posts: 74,948 U.S.S.A.
JohnRR
U.S.S.A.
Thanks guys! Sounds like the rear band isn't that crucial..but,I want something that will last a good while.The drums are factory steel. My VB is a TA Cheetah..reverse shift pattern,and of course,is manual shift.
Randy is it a low band apply VB ? If not a stock one will last longer than you will ever drive the car .
[Re: JohnRR]
#1478951
08/04/13 09:09 PM
08/04/13 09:09 PM
Posts: 2,325 Clinton Twp... north of Deetro...
Labratt
Good Ol Randy B!
Good Ol Randy B!
John....not sure if it's a low band apply....or not. How do they differ? Thanks! Randy
[Re: barracuda7199]
#1478954
08/05/13 01:12 AM
08/05/13 01:12 AM
Posts: 52,972 Romeo MI
MR_P_BODY
if it has LBA wouldn't it have engine braking in first? my turbo action cheetah has no engine braking in first so that should mean no low band apply right?
Correct... if it has LBA the engine will slow the car in manual low gear... a non LBA will just free wheel (the engine does not slow the car)
