How tight for bolts in trans pan? #1478898
08/03/13 01:43 PM
08/03/13 01:43 PM
S.e. lower MIch..
66droptop Offline OP
S.e. lower MIch..
1966 coronet 318 727.How tight should the trans pan bolts be.The torque wrench I have measures in foot pound.Thanx.
Re: How tight for bolts in trans pan? [Re: 66droptop] #1478899
08/03/13 02:12 PM
08/03/13 02:12 PM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
Checking my shop manual, in inch lbs, the torque on oil pan bolts should be 150. Converted to ft pds, that would be 12.5 lbs.
Re: How tight for bolts in trans pan? [Re: moparjo68] #1478900
08/03/13 02:34 PM
08/03/13 02:34 PM
S.e. lower MIch..
S.e. lower MIch..
They were still a little loose.Now up to specs..Thanx.....Will see how it goes later.
Re: How tight for bolts in trans pan? [Re: 66droptop] #1478901
08/03/13 04:27 PM
08/03/13 04:27 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Not real tight, you should just start to see the gasket compress a bit.
