When is it time to try locking out the distributer? #1478707
08/02/13 11:56 PM
08/02/13 11:56 PM
Taxes & Virus's R-US, NY
Dragula Online content OP
Dragula  Online Content OP
Gots few passes on the old Hemi this year, and it still seems a little lazy at the hit...When do you guys decide to try it and why? Do I need a start retard?
Re: When is it time to try locking out the distributer? [Re: Dragula] #1478708
08/03/13 06:25 AM
08/03/13 06:25 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Hey Drag Im curious re this one as well
Re: When is it time to try locking out the distributer? [Re: LAD 524] #1478709
08/03/13 06:31 AM
08/03/13 06:31 AM
Q
Quicktree Offline
Quicktree  Offline
Q
i guess when you can't figure out how to set it up correctly and leave the retard alone it's nothing but trouble
Re: When is it time to try locking out the distributer? [Re: Quicktree] #1478710
08/03/13 06:58 AM
08/03/13 06:58 AM
gregsdart Offline
gregsdart  Offline
When the cam duration gets real long the idle vacuum is so low it needs the full timing (or will tolerate it!) to idle properly. Th lower the idle vacuum, the lower the idle cylinder pressure at TDC, hence the need for more idle timing. Low cylinder pressure means a slow burn. If you have 260 degrees at .050 or more, try full advance and see. Less than that, I am not sure. It would depend on the intake closing point.
Re: When is it time to try locking out the distributer? [Re: gregsdart] #1478711
08/03/13 08:18 AM
08/03/13 08:18 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My cam is 258@.050 and it loves the timing locked out. One thing I have noticed since I locked the timing out is that when warm it always starts like its fuel injected, tap the button and its alive.
68 Barracuda Formula S 340
Re: When is it time to try locking out the distributer? [Re: Bad340fish] #1478712
08/03/13 09:22 AM
08/03/13 09:22 AM
My current cam is 260° at .050" on intake and 268° at .050" on exhaust...I already had to shorten the throw on the mechanical advance to add timing at idle to get it to idle better, but it seems like it wants more yet....right now I have it at 15° at idle, 35° total. Just seems a little lazy, but I am used to injection too....I was thinking of shortening up the mechanical advance some more, but wondered, if its that short, why not just lock it out...
Re: When is it time to try locking out the distributer? [Re: Dragula] #1478713
08/03/13 09:32 AM
08/03/13 09:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont like to lock them out unless you keep advancing
the timing to have it idle right and that point is
in the 25* area... then its less than 10* of total
advance... I like to curve the dist so it starts nice
and advances to its total at about 1500-1800rpm
EDIT
you just dont want the start of the advance point
to be at the same rpm that you idle at.. that will
cause hassles when trying to get it to idle
Re: When is it time to try locking out the distributer? [Re: MR_P_BODY] #1478714
08/03/13 10:30 AM
08/03/13 10:30 AM
ont,canada
mopartuner Offline
mopartuner  Offline
ont,canada
Does the compression or fuel you run have a bearing on this?My cam is 262/274 @ .050 and I run 94 oct pump fuel,does this make a difference?I am having a bit of an issue getting a clean idle and starting it.
410 pump gas solis flat tappet cam 10.95 so far
Re: When is it time to try locking out the distributer? [Re: mopartuner] #1478715
08/03/13 10:38 AM
08/03/13 10:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats your set up now... the dist in my Rampage is
locked at 40* right now and when its warn its a bit
to much... that dist we put in it on the dyno but I
am changing it to use advance (this is on a 416)..
the cam is 260/270 and was running 93 octane with
10.6 compression... higher compression does have a
effect on it.. the more compression the more it wants
to kick back
Re: When is it time to try locking out the distributer? [Re: MR_P_BODY] #1478716
08/03/13 10:50 AM
08/03/13 10:50 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I also think once your duration gets up to the 260s.@.050 locking out is fine, We run 32 to 34 locked depends on the fuel and air temps, If you run a hi stall converter a curved dist is not necessary, a timing retard may be needed on hi compression 14+, ya have to play with it and see what it likes.
Re: When is it time to try locking out the distributer? [Re: MR_P_BODY] #1478717
08/03/13 10:54 AM
08/03/13 10:54 AM
ont,canada
mopartuner Offline
mopartuner  Offline
ont,canada
I am only giving it 14 deg at idle/32 deg total.I want to keep the timing down a bit,my last build showed signs of detonation.I run an MSD pro billet dizzy with the largest bushing and the lightest spring.18 degree swing with the black bushing.The cam is installed at 104 cl .
Re: When is it time to try locking out the distributer? [Re: mopartuner] #1478718
08/03/13 11:02 AM
08/03/13 11:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats low base timing for a cam that big... I would
think you would be closer to 20* base and limit the
total to what you need
Re: When is it time to try locking out the distributer? [Re: mopartuner] #1478719
08/03/13 11:04 AM
08/03/13 11:04 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Bob, that's a lot of cam with pump gas compression. My old 446 started and ran fine with a 264@.050 solid and i locked the distributor out and timed it at 35*.
Same deal with the 572 i have in there now ; pump gas compression and big solid roller. Starts and idles fine...even warm with the dizzy locked out at 35*
As long as it doesn't kick back i'd say lock it out
Ron
Re: When is it time to try locking out the distributer? [Re: firefighter3931] #1478720
08/03/13 11:15 AM
08/03/13 11:15 AM
ont,canada
mopartuner Offline
mopartuner  Offline
ont,canada
I think I will lock it out,Thanks for chimming in guys,didnt mean to hi-jack........alot of issues with this new build,
Re: When is it time to try locking out the distributer? [Re: mopartuner] #1478721
08/03/13 12:22 PM
08/03/13 12:22 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Some run the starter without ignition, and then switch on, after the starter got the engine cranking.
Next step that will get the timing rock steady, would be crank trigger.
Re: When is it time to try locking out the distributer? [Re: Dragula] #1478722
08/03/13 01:34 PM
08/03/13 01:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been locked out for years w/275-280 @ .050 and 12.1.1 comp. and the start retard made it worse for me personally. Right now it`s at a conservative 32-33 degrees.............
Re: When is it time to try locking out the distributer? [Re: MR_P_BODY] #1478723
08/03/13 01:44 PM
08/03/13 01:44 PM
my own world
theraif Offline
theraif  Offline
my own world
EDIT
that the set up we have full advance @1400 rpm
Re: When is it time to try locking out the distributer? [Re: RT540] #1478724
08/03/13 06:16 PM
08/03/13 06:16 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Mine is setup so I can do that if needed. There has only been a few situations where I needed to do that. One was after driving in traffic for an hour and it was over 100* outside. It heat soaked and wanted to try and kicked back, spinning the starter and flipping the ignition switch let it light right up. Anytime I have had a kickback problem its been under extreme conditions and high ambient temps.
Re: When is it time to try locking out the distributer? [Re: Bad340fish] #1478725
08/03/13 06:20 PM
08/03/13 06:20 PM
Renton Washington
Triple Threat Offline
Renton Washington
My old motor was 11.3:1 263/268@.050 and I ran it not locked out, 25 at idle, 35 total. Pump gas. It still wanted more at idle but it ran fine.
New motor is locked out. 12.3:1, NO start retard. 36 degrees 24/7 on E85
Looking back, I should have locked the timing on my old motor as well, throttle response is much better, and they roar to life easier.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: When is it time to try locking out the distributer? [Re: Dragula] #1478726
08/03/13 09:02 PM
08/03/13 09:02 PM
Az
Crizila Offline
Crizila  Offline
Az
IMO, a locked out dist. is a race only application ( big gear, high stall, big duration cam - over 265 @.050" ) and if I were to go the route, I would be using a crank trigger set up and eliminate the dist and all it's inherent problems altogether.
Fastest 300
