10 " rear brakes #1478124
08/01/13 11:49 PM
08/01/13 11:49 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
will 8 1/4" 10 inch rear brake hardware interchange with 8 3/4"
10 inch A body rear brakes?
Re: 10 " rear brakes [Re: can.al] #1478125
08/02/13 01:08 AM
08/02/13 01:08 AM
kansas city, mo
rave_12000 Offline
rave_12000  Offline
kansas city, mo
should. remove whole assembly and swap out.
Re: 10 " rear brakes [Re: can.al] #1478126
08/02/13 02:56 AM
08/02/13 02:56 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
A body 8-3/4 brakes are unique. 8-1/4 brakes will not fit with stock A body 8-3/4 axles, the offsets are different.
Re: 10 " rear brakes [Re: nomore65BelvJim] #1478127
08/02/13 03:23 AM
08/02/13 03:23 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I'd like to know more about this.
The "offset" is built into the brake supports, right? Why couldn't an 8 1/4" brake setup work? They physically fit the 8 3/4 housing. Is it a matter of the amount of axle shaft and hub that sticks out of the housing? I have mixed and matched parts here many times and it worked out fine. Maybe I got lucky?
Re: 10 " rear brakes [Re: Kern Dog] #1478128
08/02/13 08:18 AM
08/02/13 08:18 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
A Body 8 3/4 (Small bolt pattern) brakes do not interchange. 4 1/2" bolt pattern parts will interchange from a 8 1/4 to a 8 3/4 and also a 9 1/4 and a Dana.
...FAFO...
Re: 10 " rear brakes [Re: skicker] #1478129
08/02/13 09:22 AM
08/02/13 09:22 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
i realize the 8 3/4 (4") have the narrow folded parking brake strut
which is unique and the shoes are also narrower at
1 3/4 but thought all the other hardware would interchange?
Re: 10 " rear brakes [Re: Kern Dog] #1478130
08/02/13 10:42 AM
08/02/13 10:42 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Depending on the body platform yes , EXCEPT for small bolt pattern A bodies , the axle offset is different, it's a 1/4 LESS than everything else EXCEPT for 66-69(70 ???), B bodies with 7.25 rear and 10" brakes , they have the same offset as the small bolt A body.
Re: 10 " rear brakes [Re: can.al] #1478131
08/02/13 10:43 AM
08/02/13 10:43 AM
JohnRR Offline
JohnRR  Offline
What year rear do you want to pull the brakes off of ?
I would have to look at my 69 parts manual to confirm but I want to say NO on swapping the backing plates.
Re: 10 " rear brakes [Re: JohnRR] #1478132
08/02/13 01:47 PM
08/02/13 01:47 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
My A body 8 3/4 has backing plates and correct parking brake strut
levers and actuators.
...i need drums,shoes and hardware
Re: 10 " rear brakes [Re: can.al] #1478133
08/02/13 03:00 PM
08/02/13 03:00 PM
JohnRR Offline
JohnRR  Offline
Your question is very cryptic and having to drag the info out of a person makes it harder to answer. Just an FYI , it's best to list as much info as possible when asking a question.
The shoes and the hardware are readily available , it took me less than 5 minutes to find the part numbers on rockauto.com, the hard parts to find will be the rear drums., I don't know if they are still available and if they are they will not be the flared drums as were found originally on your car.
Re: 10 " rear brakes [Re: JohnRR] #1478134
08/02/13 03:22 PM
08/02/13 03:22 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..all good points John.
Tx for the info...i know where an 8 1/4 A body rear is and wondered if just the hardware could be transferred to my 8 3/4.
Re: 10 " rear brakes [Re: can.al] #1478135
08/02/13 04:01 PM
08/02/13 04:01 PM
A body 8-1/4's are all large bolt pattern and large center register, drums wont fit.
Re: 10 " rear brakes [Re: nomore65BelvJim] #1478136
08/02/13 04:38 PM
08/02/13 04:38 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..tx Jim...i think i have a couple of the sm bolt bell drums lined up,and may be the hardest part to find if they are not useable
