Re: Blew out a freeze plug on the BIG end
[Re: hemi-itis]
#1477540
08/01/13 03:10 PM
08/01/13 03:10 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Glad your ok AL...could have been a real mess. Three things that cause soft plug failures. 1)Shallow type soft plugs. I hate them. I only use deep plugs . Period. 2) Detonation and vibration. Enuff said. 3) Painted or dirty soft plug bores. When people paint blocks, they often dont tape off ( or clean afterwartds) the paint in the soft plug openings. Paint wont help the problem. I lightly clean the bore, a small bead of #2 Permatex, three " stakes" with a chisel, and never an issue.Some circle track builds take a different approach with a more positive lock procedure. I also do use brass plugs, as I believe they conform better to the bores, and have more bite... ![](/ubbthreads/images/graemlins/Twocents.gif)
RIP Monte Smith
[Re: hemi-itis]
#1477543
08/01/13 03:34 PM
08/01/13 03:34 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Glad that you were able to save it! Getting sideways at that speed must have been a "pucker ride" for sure!! ![](/ubbthreads/images/graemlins/eeek.gif) You might want to consider installing a 'chute.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: hemi-itis]
#1477547
08/01/13 03:56 PM
08/01/13 03:56 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
Al it sux for sure but it could have been much worse. Glad your ok.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: Dap]
#1477548
08/01/13 04:26 PM
08/01/13 04:26 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
I blew a FP on my friends FED with a blown/racegas 392 Hemi. Not fun when the engine is in front of you and you get soaked with HOT water on the finish line. I now own the car and it will get a blown KB hemi and methanol and no cooler needed. Hope you get it back together soon ![](/ubbthreads/images/graemlins/beer.gif)
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
[Re: hemi-itis]
#1477551
08/01/13 07:06 PM
08/01/13 07:06 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Ron,you'd better tack the bolts holdin yer left fender on
Dont worry as my 63 will stay locked in my garage for a bit with my two killer guard dogs watching over it. Ron
![](http://pic20.picturetrail.com/VOL1620/1011563/3033688/400012592.jpg)
