Page 2 of 4 1 2 3 4
Re: Blew out a freeze plug on the BIG end [Re: hemi-itis] #1477540
08/01/13 03:10 PM
08/01/13 03:10 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Glad your ok AL...could have been a real mess.
Three things that cause soft plug failures.
1)Shallow type soft plugs. I hate them. I only use deep plugs . Period.
2) Detonation and vibration. Enuff said.
3) Painted or dirty soft plug bores. When people paint blocks, they often dont tape off ( or clean afterwartds) the paint in the soft plug openings. Paint wont help the problem.
I lightly clean the bore, a small bead of #2 Permatex, three " stakes" with a chisel, and never an issue.Some circle track builds take a different approach with a more positive lock procedure. I also do use brass plugs, as I believe they conform better to the bores, and have more bite...
RIP Monte Smith
Re: Blew out a freeze plug on the BIG end [Re: CompWedgeEngines] #1477541
08/01/13 03:22 PM
08/01/13 03:22 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
For the block, why not tack weld a "bur" to the block once the plugs are in. Hit it up on 3 or 4 spots around the plug and then it won't "Pop" out.
I may do that the next time my engine is out of the car!
Re: Blew out a freeze plug on the BIG end [Re: CompWedgeEngines] #1477542
08/01/13 03:26 PM
08/01/13 03:26 PM
Great Neck,LI,new york
hemi-itis Offline OP
Had the deep ones in there,not staked.I think I will go with the bolt in style
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Blew out a freeze plug on the BIG end [Re: hemi-itis] #1477543
08/01/13 03:34 PM
08/01/13 03:34 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Glad that you were able to save it! Getting sideways at that speed must have been a "pucker ride" for sure!!
You might want to consider installing a 'chute.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Blew out a freeze plug on the BIG end [Re: hemi-itis] #1477544
08/01/13 03:37 PM
08/01/13 03:37 PM
P
Paul_Fancsali Offline
P
Put a layer of Good silicone sealer on the outside whole plug they will not come out if you let it totally setup. And if you dojn't have to hit them hard get another plug DO NOT USE THE RUBBER BOLT IN TYPE
Re: Blew out a freeze plug on the BIG end [Re: DusterDave] #1477545
08/01/13 03:43 PM
08/01/13 03:43 PM
Thanks Dave,I'm on line to get in the chassis shop for "J" bars,knee bar and chute mounts
Re: Blew out a freeze plug on the BIG end [Re: Paul_Fancsali] #1477546
08/01/13 03:53 PM
08/01/13 03:53 PM
Thanks Paul,I don't use RUBBERS
Re: Blew out a freeze plug on the BIG end [Re: hemi-itis] #1477547
08/01/13 03:56 PM
08/01/13 03:56 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Al it sux for sure but it could have been much worse. Glad your ok.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Blew out a freeze plug on the BIG end [Re: Dap] #1477548
08/01/13 04:26 PM
08/01/13 04:26 PM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
I blew a FP on my friends FED with a blown/racegas 392 Hemi.
Not fun when the engine is in front of you and you get soaked with HOT water on the finish line.
I now own the car and it will get a blown KB hemi and methanol and no cooler needed.
Hope you get it back together soon
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Blew out a freeze plug on the BIG end [Re: MrSixpack] #1477549
08/01/13 05:25 PM
08/01/13 05:25 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow I am just glad your ok. I hate seeing your 63 banged up but as was said it can be repaired. Wish I had some extra body parts for you but I dont. Ron
Re: Blew out a freeze plug on the BIG end [Re: 383man] #1477550
08/01/13 05:30 PM
08/01/13 05:30 PM
Ron,you'd better tack the bolts holdin yer left fender on
Re: Blew out a freeze plug on the BIG end [Re: hemi-itis] #1477551
08/01/13 07:06 PM
08/01/13 07:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Dont worry as my 63 will stay locked in my garage for a bit with my two killer guard dogs watching over it. Ron
Re: Blew out a freeze plug on the BIG end [Re: 383man] #1477552
08/01/13 10:22 PM
08/01/13 10:22 PM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
That sucks but it could have been worse. Looks like you drove good enough to save it.
Re: Blew out a freeze plug on the BIG end [Re: hemi-itis] #1477553
08/01/13 10:29 PM
08/01/13 10:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
could have been worse. glad you are ok. Buddy of mine had a similar issue, his hose went, same deal pushed the fender into the rail... his is a 62 4 door. Hope you can find a fender and get it back down the track soon.
Coming soon!!!!
Re: Blew out a freeze plug on the BIG end [Re: MrFoFody] #1477554
08/01/13 10:34 PM
08/01/13 10:34 PM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
Last time that happened to me it was in the burnout box, and it popped out due to my head gasket failing and pressurising my cooling system. U may wanna look into that
Re: Blew out a freeze plug on the BIG end [Re: hemi-itis] #1477555
08/01/13 10:47 PM
08/01/13 10:47 PM
Lehigh Acres, Florida
rickstershemi Offline
Sorry for the damage.....Happy to hear your ok Al....that's what's important
Rickster
Re: Blew out a freeze plug on the BIG end [Re: rickstershemi] #1477556
08/01/13 11:09 PM
08/01/13 11:09 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Glad it wasn't worse.
I have a park lamp housing but that's all, lemme know if you need it. Lenses are repopped and widely available. Try Tony's Parts for a fender, unless you want to go 'glass.
Re: Blew out a freeze plug on the BIG end [Re: hemi-itis] #1477557
08/01/13 11:21 PM
08/01/13 11:21 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Ouch, glad your alright....
Re: Blew out a freeze plug on the BIG end [Re: 383man] #1477558
08/02/13 12:25 AM
08/02/13 12:25 AM
Those dogs look pretty mean
Will they lick me to death?
Re: Blew out a freeze plug on the BIG end [Re: Dragula] #1477559
08/02/13 12:27 AM
08/02/13 12:27 AM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
I'm glad you're ok Al.
Page 2 of 4 1 2 3 4
