Re: KH Brake Piston Removal Tool
[Re: MuuMuu101]
#1472756
07/23/13 03:08 PM
07/23/13 03:08 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
If it is not too hard, just put the other 3 pistons back in the caliper, and hook it back up to the car, use a block of wood to keep the 2 pistons from moving, and step on the brake pedal. Use the hyraudlic force to push the stuck piston out....since a liquid will not compress like air does, you have more of a chance of getting it out. If it still won't move....and if you can still get new pistons easily ? (not sure, never checked ? ) you could always drill a hole in the stuck one and tread a bolt into it, and just tighten it against the inside of the caliper to help push it out.
[Re: OzHemi]
#1472757
07/23/13 03:17 PM
07/23/13 03:17 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I haven't gotten to the point of installing the MC yet and won't get there for awhile so that won't work. Still fiddling with the pedal assembly. They sell pistons on rockauto. Centric has them for about $6 and Raybestos has them for about $13 plus super shipping.
[Re: JohnRR]
#1472759
07/23/13 04:48 PM
07/23/13 04:48 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
If possible put the piston back in next to the stuck one and hold it in place wit ha clamp , grease the seal if you can reuse it , and try forcing the stuck one out that way ?
But as stated if the bores are rusty you will have to get the bores sleeved.
I was able to do that with my pieces of wood. I had all 4 pistons in the bores (no seals) and shooting the compressed air into the caliper and as far as I could tell I wasn't getting any leaks around the pistons. Most of it, if any, was just back trailing out of the inlet where I was shooting the air. I think the shop air is somewhere around 60psi, but don't quote me on that and I can't change the setting.
[Re: JohnRR]
#1472761
07/23/13 05:33 PM
07/23/13 05:33 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Does it move at all or is it just locked in there tight ?
You may need to restort to hyd. pressure to get it out of there . do you have a brake rebuilder in the area ?
It was locked. Idk much about any brake restorer around; however, I've never checked.
[Re: MuuMuu101]
#1472762
07/23/13 05:52 PM
07/23/13 05:52 PM
Posts: 27,558 So Cal
autoxcuda
So Cal
Just use them as cores and get some rebuilt Centric 4 piston calipers. Can get them at www.rockauto.com or a good parts store. Shop around. Will be cheaper than having someone rebuilt yours.
[Re: autoxcuda]
#1472763
07/23/13 05:58 PM
07/23/13 05:58 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Any difference between Cardone, Raybestos, and Centric when it comes to quality? Can I send these in as cores without the pistons or will I have to reinstall the pistons?
Edit: Just checked and they don't have one of the Centric calipers in stock. ~$150 for new reman calipers.
[Re: stumpy]
#1472765
07/23/13 06:38 PM
07/23/13 06:38 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
If you buy from the local parts store you can just take the cores in without the pistons installed. Just put all the parts together in a box or bag. They don't care if it's in one piece.Check for prices on other brands.
Rockauto is going to cost me about $160 after I get reimbursed for cores (assuming it cost $25 to ship the cores back to them). The local parts stores are going to cost me about $260 and that's after the cores are returned.
[Re: MuuMuu101]
#1472766
07/23/13 10:04 PM
07/23/13 10:04 PM
autoxcuda
So Cal
I'd keep working on them for $260. Have you tried shopping around to other parts places to get near $160.
[Re: autoxcuda]
#1472767
07/24/13 02:04 PM
07/24/13 02:04 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I checked all the major ones (Pep Boys, Autozone, NAPA, O'Reilly, etc.) and that was pretty much the baseline price. I don't know of many mom and pop parts stores near by. I just called the local mom and pop store near me with amazing Yelp reviews and they said they could get them to me this afternoon for $145 each + tax...
http://www.yelp.com/biz/eds-auto-parts-covina
[Re: MuuMuu101]
#1472772
07/25/13 03:43 PM
07/25/13 03:43 PM
OzHemi
Garden Grove, CA
Why not use the local store that could get them for cheaper than rock ?
Sorry, I didn't make myself clear. I can get both from rockauto for $160 after the core reimbursement. At the local store it would be approximately $290 after core reimbursement.
Rockauto: ~$63-65 each with a $56.25 core charge
Stores: ~$120-145 each with a $30 core charge or less
Ooooooooooh.......Now I see.
Must have been the morning cloud cover getting in the way of my screen.
[Re: OzHemi]
#1472773
07/28/13 07:35 AM
07/28/13 07:35 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
I think I read somewhere to try grease. Put a zerk in one hole and plug in other, put piston back in and clamp with c-clamp then use grease gun. Hydraulic pressure may do it.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
