this ain't good.
#1471976
07/22/13 04:49 AM
07/22/13 04:49 AM
Posts: 4,648 aotearoa
rebel
aotearoa
Re: this ain't good.
[Re: rebel]
#1471979
07/22/13 08:45 AM
07/22/13 08:45 AM
Posts: 10,024 Frostbitefalls MN (Rocky&Bullw...
gregsdart
From the sound of it it was a throttle linkage problem. It hung up when he stopped the burnout, then when He tapped the throttle to back up it went wide open. Probably lost the return spring? He should have hit the fuel shutoff/kill switch the instant he knew there was a throttle problem. And finally, where are the safety guys with some balls. That car ran over 40 seconds against that wall without an attempt to shut it down. They got there, but slow in my opinion. ANYTIME you see a car crash the safety guys should be instantly running that way with extinguishers. I have been sideways at speed and seen the safety guys at BIR running towards the guard rail in case I went on my lid. Now that is the kind of reaction I can appreciate! I was glad to be able to wave at the guy as I coasted by!!
[Re: gregsdart]
#1471980
07/22/13 11:44 AM
07/22/13 11:44 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Yeah he had a throttle problem and also he had the caster WAY out there which can cause the wheels to flop over when backing up(great for going forwards but thats what happens when backing up).... as soon as the front started turning sideways he thought he could correct it by putting in in drive to straighten it out BUT then the throttle went open... basically his whole problem was a throttle issue EDIT I seen John Forces FC do the same on the front wheels when he backed up to fast... some times they get into the death wobble when backing up, where they start flopping side to side.. if you have a hold on the steering then it can break your wrist... you just need to stop ![](/ubbthreads/images/graemlins/wave.gif)
[Re: gregsdart]
#1471983
07/22/13 12:30 PM
07/22/13 12:30 PM
Quicktree
the car was slinging burning rubber everywhere. you couldn't have got close if you wanted to. the driver was probably knocked out the first hit on the wall. they did pretty good under the circumstance.
[Re: Quicktree]
#1471984
07/22/13 07:57 PM
07/22/13 07:57 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
A bad scene, good thing he will be OK. I know hindsight is always 20-20, but when the motor was obviously idling too high after the burnout, he should have shut it off. With open injector stacks, something probably got into one of them, holding the butterfly open. Every blip of the throttle, just let it fall in further, holding the throttle open more. That was an extreemly dangerous situation for the saftey crew to approach. One of the slicks could have exploded at any time and killed anyone in its path. Too get close enuff to kill the motor, they put their own life in much more peril than the driver was in. ![](/ubbthreads/images/graemlins/Twocents.gif)
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: bonefish]
#1471986
07/22/13 10:35 PM
07/22/13 10:35 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
The guy was making his license runs. When he was backing up the engine started running away again he reached for the handbrake but grabbed the shifter instead.... from one of the guys who was helping him. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: mr2performance]
#1471988
07/23/13 09:53 AM
07/23/13 09:53 AM
Challenger 1
Cincinnati, Ohio
I went to a drag school back in 1992. They taught us to sit in the car bindfolded and use the controls because you can't see them very well with a helment on. Which I did for several hours long before the car was even ready to go. It helped a lot. There's lot's of things to do in a alky dragster, like letting the clutch out when the lights go yellow, trying to keep the Rs at 5800 during staging, shift twice in 3 seconds and pull the chuts before the finish line like a 1/2 second after putting the car in hi gear. Not to mention steering.
I could do all that bindfolded, swear.
Also I have run stack injected BBC motors like he had. I setup 2 different injectors, one for a BBC and one for big chief pontiac. I bet the linkage was not setup correctly and allowed it to go over center. ![](http://i21.photobucket.com/albums/b260/challenger19711/phase%204/MVC-075S-1.jpg)
[Re: '72CudaRacer]
#1471990
07/23/13 09:39 PM
07/23/13 09:39 PM
MR_P_BODY
A friend of mine ran an old slingshot dragster with a 440 and the short stack fuel injection, on alcohol. If there was the slightest bit of humidity in the air, it would try to ice up the inj linkage after the burn out. Sometimes the throttle blades wouldn't shut completely and be idling at 2500 or more and that just compounded the problem. Looked like to me that he turned the steering wheel when he put it in reverse. And anyone thats ever been around a old slingshot digger knows that when you're backing up, even slowly, there is almost no weight on the steer axle. Tough way to learn though. Thankfully, most of us got our experince with out these kinds of results. (and everyone of us was a rookie once)
Brian Dunnigan
If you dont hold the steering wheel straight with a bunch of caster the tires/wheels will flop over( its like a road grader).. the faster you go in reverse the more they want to flop sideways ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Hemi_Joel]
#1471992
07/24/13 08:04 AM
07/24/13 08:04 AM
gregsdart
"That was an extreemly dangerous situation for the saftey crew to approach. One of the slicks could have exploded at any time and killed anyone in its path. Too get close enuff to kill the motor, they put their own life in much more peril than the driver was in." Good point, Joel.
