'06 Grand Caravan Check Engine Light
#1471611
07/21/13 05:49 PM
07/21/13 05:49 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Just wondering what codes I can decipher at home. Wife said oil, coolant, temp was fine.
3 quick turns on the key?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: '06 Grand Caravan Check Engine Light
[Re: Rug_Trucker]
#1471612
07/21/13 07:44 PM
07/21/13 07:44 PM
Posts: 12,296 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Most manufacturers have eliminated the self diagnose function. But most any AutoZone or O'Reilly's or the like provide scan service free.
Master, again and still
[Re: Rug_Trucker]
#1471614
07/21/13 11:09 PM
07/21/13 11:09 PM
Posts: 3,394 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Our 05 Caravan will still self-diagnose with 3 key turns. Not sure if an 06 will.
Try it and look the codes up on the internet.
That will get you pretty far.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: Rug_Trucker]
#1471615
07/22/13 01:59 PM
07/22/13 01:59 PM
Posts: 52 CO
Twisted
CO
Key dance still works on our 05, should on yours too. 9 times out of 10 the gas cap was loose, 10th time was battery related.
Thank you Aaron
69 Dodge Polara 4DHT 70 Plymouth Duster 03 Dodge Neon R/T 05 Dodge Grand Caravan SXT
[Re: DaveRS23]
#1471617
07/23/13 12:52 PM
07/23/13 12:52 PM
Rug_Trucker
PO406 EGR valve?
Is that the thing on the passenger side exhaust manifold with the wires hanging out?
[Re: Rug_Trucker]
#1471618
07/23/13 09:23 PM
07/23/13 09:23 PM
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
On most vans they are above the alternator.
Wire mounted on top of a solenoid with a heat-shielded tube coming up to the top of the intake.
I just did one on the van where I work. Easy job.
[Re: Rug_Trucker]
#1471619
07/23/13 10:24 PM
07/23/13 10:24 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Sounds right. They are a little pricey at the auto supplies. If you have a pick a part yard near you, they go for $5-$10 usually.
The bottom bolt is a little tough to get to. I usually grind the small hump and bolt on top of the alternator to get access to the lower mounting bolt. And using a 1/4" drive helps, too.
