Wieghed the Six Pack Attack Bee... Heavy! Update w/ Pic
#1470766
07/20/13 01:26 AM
07/20/13 01:26 AM
Posts: 903 Saskatchewan, Canada
cudabin
Just for fun we put my 1970 440 Six Pack, Super Track Pack Super Bee on the scales last night... Heavy... It weighed 4,005 pounds without the driver, but full of fuel and with the spare tire and jack in the trunk. Cast iron Six pack intake,Cast iron HP Exhaust Manifolds and full Stock exhaust w/ chrome tips. Big Red top Mopar resto Battery up front, and full size starter, cast iron water pump. 15X7" rally wheels with 235/60R15 Radials including same size spare. Corners were: LF = 1,236 RF = 1,071 LR = 794 RR = 904 Front percent = 57.6% Rear percent = 42.4% It is going to take all 450HP and 508 lbs/ft TQ to move this Heavy Bee Will be interesting to hit the track once this fall. Cheers, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Wieghed the Six Pack Attack Bee... Heavy!
[Re: DANA60]
#1470772
07/20/13 12:18 PM
07/20/13 12:18 PM
cudabin
Not sure how the scales are off? Same Rebco scales weighed my Cuda at 2,775#'s w/ me in it and that isn't heavy... We did zero them out and lower properly. I know that the 69 cars are a lot lighter with the lift off hood, and Aluminum intake. Cheers, Arnie
[Re: cudabin]
#1470773
07/20/13 12:19 PM
07/20/13 12:19 PM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
Apple-to-orange comparo............ my 69 RR post, w/no spare/jack, 1/4 tank fuel, aluminum intake/front wheels, steel tube headers, race buckets, no radio (or other options for that matter other than drip mouldings), B-motor 383, stock steel hood, aftermarket open aircleaner........... w/o me 3440 lbs.
[Re: RUNCHARGER]
#1470778
07/20/13 10:26 PM
07/20/13 10:26 PM
That sounds about right. The lighter B-Bodies seem to be the 66-67 cars with their small tires, no dana if an automatic and no extra scoops etc. They seem to be in the 3700 range for the no option cars.
Sheldon
The 66-7 Charger's weren't light, though. My 67 Hemi Charger weighs 4125 with a full tank of gas, no driver. Auto and 8 3/4, no PS or PB.
Super Stock and Drag Illustrated tested a 66 Satellite with Hemi and a 4-speed and it was a couple hundred pounds lighter, even with the Dana rear.
#1470779
07/21/13 02:42 AM
07/21/13 02:42 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I hate to hear it's such a heavy car since I have a 70 Bee. Mine is a 3.23/auto so it came with a 22" radiator. The lighter radiator and a change to a CH6 intake, aluminum w/p housing and a mini starter may knock 40-60 lbs off but that will still put me at around 3950. Time to think about discs on the front instead of the 11x3 drums when I put it back together.
[Re: cudabin]
#1470781
07/21/13 11:08 AM
07/21/13 11:08 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I weighed my 68 GTX back in the eighties 440 auto, dana rear end buckets counsel power steering and 4 piston power disk brakes, frame connected and steel hood. (plus some bondo I'm sure :-)) Anti sway bar on front, full duals al the way to the back bumper, 3 core 26 inch rad, Cragar SS (heavy) and Pro track M50 15s out back G60s front full tank of gas no spare or jack but a small tool box. Aluminum intake and headers was the only weight saver then. It was 4004 lbs without me in it so 4239 with my fat ass. Ahh the good old days when I was only 235 :-) Now it is somewhere around 3700 with me in it. Maybe less got to weight it again was 3716 two years ago?? Anyway anti sway bars gone, steel hood gone, interior gone, heavy rims gone, heavy rad gone, heavy power steering and brakes gone, radio gone, exahust gone. even the sure grip to spool was quite a bit of weight. Aluminum heads and rad now. Still all steel and glass save for the hood but I like it that way. Me 260 now that's not helping! :-)
[Re: cudabin]
#1470783
07/22/13 06:34 AM
07/22/13 06:34 AM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
I love it when guys are positive of the cars weight,because the title says so.usually never even close to real weight,lol.
So are you saying my Super Bee is lighter than what the Rebco scales say even thought they have been accurate for many other race cars including my Cuda??????
Curious as to why you think that...
I guess I don't understand your question....but what I ment was many fellows use title weight as gospel,on what their car weighs....when many times it is way off,and car has been heavily modified since new,or the factory used a base model weight for a non-based car. that's all I ment by my comment,and I find it funny,hence the graemlin.....I did not make any comment about acual scales,or your super bee. im curious what your title weight states vs actual weight by your own scales????...and as far as what I think about your comment...I have none...I really don't know what you mean? ,but im sorry if I offended you your scales,or your super bee. ...mike
Arnie
[Re: imfixinmopars426]
#1470784
07/22/13 08:24 AM
07/22/13 08:24 AM
cudabin
No worries, I now understand what you meant by "title". I originally thought you meant the title of my thread... No offense taken, and i actually wish the scales were lying as 4,005 pounds is a lot to get rolling. Cheers, Arnie
