Steering help #1470131
07/19/13 02:54 AM
07/19/13 02:54 AM
Iowa
E
eaglesguy1981j Offline OP
E
Iowa
Im pretty much a noob! But I have a 72 Scamp ive been building. Using 73+ A body parts. I have more travel to the passenger side then i do the driver side. I have confirmed that the tie rods are 12 1/2" on both sides. I get about 4 turns lock to lock manual steering. When i turn it all the way to once side then back 2 the wheels are not straight! Thoughts on a starting point?
Re: Steering help [Re: eaglesguy1981j] #1470132
07/19/13 03:05 AM
07/19/13 03:05 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
is the pitman arm clocked right ? Then an alingment
I am truckless..
Re: Steering help [Re: 340SHORTY] #1470133
07/19/13 03:12 AM
07/19/13 03:12 AM
Iowa
E
E
Iowa
Im not sure to be honest. I know i get way more travel to the pass side then I do the driver side. Looking though the FSM now to see. How would i tell if its not clocked right?
if i undo the pitman arm set the wheels straight. turn the gear box all the way to one side and back counting the turns then splitting the difference... if the pitman arm is clocked right it should line up?
