SB Timing Pointer Location? #1469536
07/17/13 09:44 PM
07/17/13 09:44 PM
Out West
408strokerdart Offline OP
Out West
Does anyone know the orientation for the balancer timing mark as Ma Mopar designed it? Maybe in degrees from straight up? I have measured two different timing covers and just want to make sure before I start machining parts. I'm only doing drivers side pointers at this time.
Re: SB Timing Pointer Location? [Re: 408strokerdart] #1469537
07/18/13 11:20 PM
07/18/13 11:20 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
On my ATI damper , TDC is approximately 1:00 when looking at it from the front.
I took a BBC pointer and mounted it to the motor plate so I could time it , but if you come up with a decent part ( I expect no less ) , I am all in.
edited to add.......I just went out and checked.....35 degrees from 12:00 is what it looks like.
Re: SB Timing Pointer Location? [Re: tubtar] #1469538
07/19/13 12:00 AM
07/19/13 12:00 AM
Out West
Out West
I put my digital level on the front and zeroed it out straight up, then rotated it over to TDC (actual indicator verification) and read it as 37 degrees. My design has 4 degrees of adjustment both ways so it should be covered. Sending out drawings to have parts made.
Re: SB Timing Pointer Location? [Re: 408strokerdart] #1469539
07/19/13 10:38 PM
07/19/13 10:38 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
I just may want one Brian, Are you getting close on the next batch of water manifolds?
Re: SB Timing Pointer Location? [Re: Hitman340] #1469540
07/19/13 11:36 PM
07/19/13 11:36 PM
Out West
Out West
Yes Jeff. I actually have yours on the bench waiting to go to the finisher with a large batch of items to be anodized.
