Hoodscoop finally showed up! #1469508
07/17/13 09:24 PM
07/17/13 09:24 PM
Perryopolis PA
turbododgepirate Offline OP
Perryopolis PA
The custom scoop for my pickup finally showed up. Basically a hemidart scoop raised to 5 inches. It might be too big...
Re: Hoodscoop finally showed up! [Re: turbododgepirate] #1469509
07/17/13 09:34 PM
07/17/13 09:34 PM
Perryopolis PA
Perryopolis PA
A shot from the side. Some trimming for fitment will obviously have to be done.
Re: Hoodscoop finally showed up! [Re: turbododgepirate] #1469510
07/17/13 10:03 PM
07/17/13 10:03 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
You could always put a handle on it and shovel a lot of snow in the winter..
I am truckless..
Re: Hoodscoop finally showed up! [Re: turbododgepirate] #1469511
07/17/13 10:03 PM
07/17/13 10:03 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Hemi Dart A body ? ... that is what it was sold to you as ? ... SURE looks to me like a way-taller 66-67 Hemi B-body scoop ...
Re: Hoodscoop finally showed up! [Re: dOoC] #1469512
07/17/13 10:07 PM
07/17/13 10:07 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
will you be adding a center post for support on the opening?
I like it. Bigger is better, and you can catch bigger birds!
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Hoodscoop finally showed up! [Re: hp383] #1469513
07/17/13 10:14 PM
07/17/13 10:14 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Two or maybe even THREE of them supports ... just go to a hardware store and get some 1/4x20 Tee nuts ..
Re: Hoodscoop finally showed up! [Re: dOoC] #1469514
07/17/13 10:51 PM
07/17/13 10:51 PM
scratchnfotraction Offline
I was thinking the same thing looking at it. my 68 Hemi dart scoop looks mucho different.
what size hole you going with under the scoop?
I went as large as the scoop to help under hood temps running manifolds,less ramair stacking up trying to rip scoop off.
so far it has been 115 mph for 5 miles with out blowing off.
I do need to get my 2 alum support post installed in the opening. it does shake around at speed but very little.
what a hole! what a hole!
Re: Hoodscoop finally showed up! [Re: scratchnfotraction] #1469515
07/18/13 02:40 AM
07/18/13 02:40 AM
Perryopolis PA
Perryopolis PA
Yup, it's a 66-67 scoop but raised to 5 inches. I do plan at least 2 support posts. I thought it would slope more in the back. But oh well.
Re: Hoodscoop finally showed up! [Re: turbododgepirate] #1469516
07/18/13 06:28 PM
07/18/13 06:28 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
all done
I am truckless..
Re: Hoodscoop finally showed up! [Re: 340SHORTY] #1469517
01/31/14 08:31 AM
01/31/14 08:31 AM
Perryopolis PA
Perryopolis PA
Painted and installed.
Re: Hoodscoop finally showed up! [Re: turbododgepirate] #1469518
01/31/14 09:37 AM
01/31/14 09:37 AM
Truckville, the capital of NY
85_Ram_4speed Offline
FYI, you can use a carrige bolt and go from the top of the scoop down into the hood for a cleaner look. Just use a file to make your round hole square to accept the under head of the bolt.
Then you can use a plastic sleeve (or metal)for the bolt to go through to support the scoop underneath so when you tighten it down, it doesn't suck the center of the scoop down like you have.
Outcast Dodge guy.
Re: Hoodscoop finally showed up! [Re: turbododgepirate] #1469519
01/31/14 03:56 PM
01/31/14 03:56 PM
Winnipeg, Manitoba, Canada
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
This is the scoop I used on my Crew. My friend Brett has the truck now and he is not a hood scoop guy so he gave it back to me.
Re: Hoodscoop finally showed up! [Re: 4dr4x4] #1469520
01/31/14 08:00 PM
01/31/14 08:00 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Love the OP's truck, but that scoop... I'm just not feelin' it. I've got plans kickin' around in my head to build a similar truck in the future and I know most Mopar guys don't like 'em, but I'm going to build my own steel cowl hood. I'll actually use the original hood skin as the top of the cowl in hopes of keeping that factory center body line.
Re: Hoodscoop finally showed up! [Re: pinkduster] #1469521
01/31/14 09:33 PM
01/31/14 09:33 PM
well I only showed how big a hole my scoop has.
I am looking into making my own Rod Hall Baja hood/scoop for my stepside
Re: Hoodscoop finally showed up! [Re: scratchnfotraction] #1469522
01/31/14 09:36 PM
01/31/14 09:36 PM
but a paint job like this with a lowerd non scoop hood
Re: Hoodscoop finally showed up! [Re: scratchnfotraction] #1469523
01/31/14 09:42 PM
01/31/14 09:42 PM
and here is my 68 Hemi scoop covering the big hole in the hood.
Re: Hoodscoop finally showed up! [Re: scratchnfotraction] #1469524
01/31/14 09:43 PM
01/31/14 09:43 PM
Re: Hoodscoop finally showed up! [Re: scratchnfotraction] #1469525
01/31/14 10:02 PM
01/31/14 10:02 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Sn' ...is that a plastic scoop ?
Re: Hoodscoop finally showed up! [Re: turbododgepirate] #1469526
01/31/14 10:30 PM
01/31/14 10:30 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Maybe just run with the hood wide open and use some cable to hold it there.
Yes, it's a little big.
Whatever turns your crank though, . I am of the opinion hood scoops don't belong on trucks except for one: the SRT Ram.
Let 'er rip, you'll turn some heads!
Mo' Farts
Moderated by "tbagger".
Re: Hoodscoop finally showed up! [Re: Grizzly] #1469527
01/31/14 11:11 PM
01/31/14 11:11 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I really thought about adding a hood scoop to my D150 but ended up putting a Spectre ram air system on instead. Its a nice chrome air cleaner with two snorkels with tubes connected to the air source, I put a 4 inch hole in the radiator support on the left side added a screen and now it pulls fresh air from behind the grille on the other side rather than make another hole and be close to the battery I just connected to the factory air intake box which pulls fresh air from under the turn signal.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
