Do these tubes look like manufacture defect? #1468099
07/15/13 10:25 AM
07/15/13 10:25 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Just want to make sure not over reacting
Re: Do these tubes look like manufacture defect? [Re: Dart451] #1468100
07/15/13 10:52 AM
07/15/13 10:52 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Looks like they were stored for a long time wrapped up. I might try to air them up to 15-18 psi and let them sit in the sun for a half hour or so to see if they find their original shape.
Re: Do these tubes look like manufacture defect? [Re: tubtar] #1468101
07/15/13 11:23 AM
07/15/13 11:23 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Sounds like a good idea
Re: Do these tubes look like manufacture defect? [Re: Dart451] #1468102
07/15/13 01:56 PM
07/15/13 01:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I wouldnt run them even if they look right after some heat.I run tubes in a few of the old Harleys and if I had one like that it would go back or in the trash.Been installing tubes in car and motorcycles since the 60s.Rocky
Chrysler Firepower
Re: Do these tubes look like manufacture defect? [Re: Dart451] #1468103
07/15/13 02:04 PM
07/15/13 02:04 PM
I've seen tubes that look like that after they had been installed in a set of tires that had a fold in the tube like yours look like in your picture. They would usually smooth out after a few days when inflated up like yours are now Look very closely at yours, if the seration on the outer sides are missing in the fold DON'T use them If they are missing then I'm sure thier defective from the maker
Re: Do these tubes look like manufacture defect? [Re: Dart451] #1468104
07/15/13 02:25 PM
07/15/13 02:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Those are defective... period... I run tubes in my
slicks all the time... never seen that.. send them back
Re: Do these tubes look like manufacture defect? [Re: MR_P_BODY] #1468105
07/15/13 03:11 PM
07/15/13 03:11 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I fully agree!! the factory inspector must of been asleep when that one went by.
Re: Do these tubes look like manufacture defect? [Re: MR_P_BODY] #1468106
07/15/13 03:23 PM
07/15/13 03:23 PM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: Do these tubes look like manufacture defect? [Re: Crizila] #1468107
07/15/13 03:46 PM
07/15/13 03:46 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Called MT an Emailed them pics see what thay say.
Re: Do these tubes look like manufacture defect? [Re: Dart451] #1468108
07/15/13 10:51 PM
07/15/13 10:51 PM
I would order a new set from Jegs or Summit and check them over right away, if the new ones are good return the bad ones to them as defective
Re: Do these tubes look like manufacture defect? [Re: Cab_Burge] #1468109
07/15/13 10:55 PM
07/15/13 10:55 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
???????????????????????????????????????? REALLY? joking right?
