Re: piston selection help?
[Re: moparsquid]
#1467876
07/15/13 01:24 PM
07/15/13 01:24 PM
dogdays
Just to clear up a couple of points.....
The original 440 strokers used the 4.15 crank, LY rods and 400 pistons. That's from back in the day when any real 440 stroker pistons would have been custom and $$$$$.
Lots of engines were built that way.
Lots of sets of LY rods have been into the 10s. I bet lots of cast pistons, too.
So I don't think you got less than what you were told. It sounds like a pretty nice street engine to me. Did he specifically tell you the engine had aftermarket forged pistons or rods? I bet you ASSUMED that, because that's how most strokers are built nowadays. I also bet you haggled on the price.
The main reason for cracked piston ring lands is improper assembly of piston into block. It's a workmanship problem, not a material problem.
R.
[Re: moparsquid]
#1467881
07/15/13 04:20 PM
07/15/13 04:20 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
How many miles did you put on it??? So 7400 all together or 5000 to 6000 with victor heads. Check the rings for butting it's such a low buck build probably not balanced and may have put + .060 rings in maybe that's whats pulling the pistons apart. cross hatching still on the cylinder walls. did it have steel or composition gaskets.
[Re: Dodgem]
#1467885
07/15/13 05:46 PM
07/15/13 05:46 PM
Posts: 1,107 Spring Valley ,Ca.
moparsquid
Spring Valley ,Ca.
Pictures of everything lots of pictures?
ill try and get some pics today and ill post it later
[Re: moparsquid]
#1467886
07/15/13 08:32 PM
07/15/13 08:32 PM
Dodgem
Ontario, Canada
wow 2 miles either it was well used or something else hear?? Check the ends of the top to rings to see if they butted?? They will show shiny polished look if they did should be able to see. any scrapping on the cylinder walls?? Are they real edelbrock heads or the Chinese I'm a knock offs?? all the cam lobes look OK?? Hydraulic and way to measure it take it out and measure the width and the hieght of the lobes difference may tell you a bit
[Re: moparsquid]
#1467888
07/16/13 09:17 AM
07/16/13 09:17 AM
Dodgem
Ontario, Canada
Make sure you check them top rings for butting! what kind of troubles was it giving you? If that's all you did everything should still look brand new.
