727 Torqueflite how to corrrect late 1 to 2 upshift
#1467049
07/12/13 08:29 PM
07/12/13 08:29 PM
Posts: 338 Montreal Quebec
STROKIE
Montreal Quebec
I just install a TF-2 Transgo reprograming kit and a A&A 5800 Rpm governor in my 727. Now my full Throttle 1-2, 2-3 upshift is ok... But 1-2 part throttle shift at 2500 rpm not very pleasant... 2-3 upshift is acceptable. How can have a more lower 1-2 upshift
Re: 727 Torqueflite how to corrrect late 1 to 2 upshift
[Re: STROKIE]
#1467051
07/12/13 08:46 PM
07/12/13 08:46 PM
Posts: 30,253 Florida STAYcation
dIc dOc Deity !
The village idiot's idiot
Florida STAYcation
THOSE are the typical "issues" with a higher-rpm GOV package ....
[Re: d-150]
#1467056
07/13/13 12:39 AM
07/13/13 12:39 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I'm using a Fairbanks kit in my 518, and have the stage 2 setup. I have about the same 2500RPM shift point.
I actually wish mine would shift a bit harder. Next time I will use the stage 3
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: RapidRobert]
#1467060
07/14/13 04:58 PM
07/14/13 04:58 PM
STROKIE
Montreal Quebec
To much trans throttle pressure can also cause higher upshifts. Ron
Yes you might shorten the kickdown linkage & see what happens. It'd be easy to set back to where it was.
As per suggestions I shortened 4 turns the kickdown linkage... I road test the Dodge Wow... 1 to 2 shift occurs at 2000 instead of 2500 Rpm. More pleasant I would like to know if this modification affect the kickdown, now the transmission lever don't go to the maximum.
[Re: stumpy]
#1467062
07/14/13 05:17 PM
07/14/13 05:17 PM
STROKIE
Montreal Quebec
It's not necessary for the linkage to be fully back to kickdown. If it downshifts when you get on the gas then it's fine.
Thanks... When I road test it downshift no problems. May be I can shortened more the linkage to have lower 1-2 upshift around 1500 Rpm
[Re: STROKIE]
#1467063
07/14/13 09:11 PM
07/14/13 09:11 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you keep shortening the linkage you will eventually reach a point where it won't kickdown at WOT....at that point it's time go back to the last setting and call it good.
[Re: John_Kunkel]
#1467064
07/14/13 10:13 PM
07/14/13 10:13 PM
STROKIE
Montreal Quebec
Thanks John... With your knowledge you really help us...
