Re: 2004 Ram 2500 4x4 - Chirping noise from front
[Re: superwrench]
#1466109
07/10/13 10:56 PM
07/10/13 10:56 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
The rear CV joint in the front drive shaft can squeak. The centering ball between the two joints and it's seal get dry. Try spraying a decent lube (not a penetrating oil) up between the joints. This was a real problem with Dakotas and 1500's thru the late 90's and early 2000's. People changed a lot of stuff they didn't need to....
Yep as I fixed that a few times working at the Dodge dealer. Ron
[Re: 74Charger]
#1466112
07/16/13 06:39 PM
07/16/13 06:39 PM
Posts: 18,160 Mass
DAYCLONA
Mass
My truck has developed a faint chirping noise that speeds up and slows down based on wheel rotation speed.
I checked the calipers, shims, and pads last weekend but could find nothing wrong
I rotated the front hubs with calipers removed and could feel it was a bit less than consistent as far as drag goes.
I'm wondering of the front hub bearings are worn and approaching failure. Truck has 142,000 miles.
Anyone know of any history on this symptom, and a solution or it?
Hub replacement is fairly difficult and costly from what I have heard.
Let's face it, even if it's "just" the U joint you still have to pull the hub assy to pull the axle shaft, best to replace the hub and U joint if your going to tear it down, the factory hub assys are good for about a max of 150K, your just about there, whatever you do, buy the premium hub assy, don't cheap out, I did this and got about 20K on a cheap China set before I had to pull them again, busting them out the first time can be tough, a cold chisel, or impact chisel helps force them out of the knuckle, you'll need a thinwall socket, 36 MM IIRC for the front axle nut, and be sure to torque it back in place, 125 ft lbs IIRC, the hub assy is pretty simple to deal with, it's just prying them out of the knuckles that's a PITA, 2 bolts holding the caliper, 3 12 point bolts holding the hub assy from the backside of the knuckle, and of course the axle nut, put some anti-seize inside the hub bore before installing the new hub assy, and install a premium GREASE-ABLE U joint...
Mike ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: DAYCLONA]
#1466114
07/19/13 05:35 PM
07/19/13 05:35 PM
Posts: 17,918 S.E. Michigan
ZIPPY
S.E. Michigan
Mike
what he said.
If you like the truck and want to keep it, replace both hub bearings and the u joints with quality pieces. It is not an easy job but once you get it done it will be all set for a long time.
Rich H.
Esse Quam Videri
[Re: 74Charger]
#1466116
07/28/13 03:54 PM
07/28/13 03:54 PM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Well, i have replaced both hub bearings, both front axle u-joints,and the upper RH ball joint, and I still have this chirp that gets faster with wheel rotation.
I''m now thinking driveshaft issues...... ![](/ubbthreads/images/graemlins/confused.gif)
Any ideas?
Remove the front shaft and drive it.
[Re: 74Charger]
#1466117
07/28/13 04:19 PM
07/28/13 04:19 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Any ideas?
...Like I said on here two weeks ago..... could have save ya a lot of money and aggravation ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: 74Charger]
#1466119
07/28/13 05:20 PM
07/28/13 05:20 PM
superwrench
I'd just unbolt the whole shaft. If you look close the shaft, it "MAY" have a inverted grease fitting at the ball socket in the CV joint. I don't believe it will in those years.If you can get a small pick under the lip of the seal and squirt some sprayable grease (even white lithium spray) under the lip,in a few spots. The noise could actually be one of the u-joints...look for a rusty residue around the cap seals at the inner part of the crosses. All I can say is that this particular problem caused more headaches than I can count..... and as you have shown, a lot of unneccesary work. On the bright side, you now know your front end is in pretty good shape.
[Re: superwrench]
#1466120
07/29/13 02:42 AM
07/29/13 02:42 AM
Posts: 172 IL,USA
bdusted440
IL,USA
well why not do a proper diagnosis instead of shotgunning it.[throwing parts at it].Get it in the air all 4 wheels, start it and put it in drive. Now listen for the noise.is it there? If no put it in 4wh. Is the noise there? If you here the noise try to isolate it. I use a stethoscope.a long screwdriver works good to. Put one end on the part the other up to you're ear tight and listen. Put the screw driver on the closest to the noise NON MOVING PART. Then move say 6" away. Is it louder or not? If you hear it at the trans or rear diff listen on both sides as it will travel. And narrow it down. A very abbreviated diag formula. Hope it helps.
currently own 1976 duster deluxe 1974 gold duster 1993 Dakota sport 2000 caravan 2002 Durango 1970 v code superbee
[Re: 74Charger]
#1466121
07/29/13 11:47 AM
07/29/13 11:47 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
a couple of points: ive seen many a chirp, squeak, type sound caused by the anti rattle shims dragging on the rotor. also rust on the outer edge of the rotor hitting the caliper. to remove the hub, I back the bolts out until there is 1/2" or so clearance to the knuckle, and use the socket with an extension to brace against the spring, axle housing, whatever is easiest, start the engine and turn the wheel. pops them right out. (this doesn't seem to work on the 1500's) and IIRC the axle nut torque is 175#.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: superwrench]
#1466122
07/31/13 12:39 PM
07/31/13 12:39 PM
Posts: 174 Creedmoor, NC, USA
74Charger
Creedmoor, NC, USA
Your diagnosis was "dead-on" correct! I lubed that center of the double u-joint at transfer case and no more chirping! FYI - the 2004 models have no inverted grease fitting like the 2008 and later trucks. I'm not feling too badly about the hubs and u-joint replacements at 142,00 plus miles. I got the "best" out of them, and should be good to go for a long time now. Also, I had to replace an upper right side ball joint that was loose, so I would have replaced hub and u-joint at the same time regardless. Now it is close to time for new tires! I wasn't doing that and front end alignment with a bad ball joint. Thanks! ![](/ubbthreads/images/graemlins/beer.gif)
