98 Ram SS/T oil pressre switch connector. #1465669
07/09/13 11:00 PM
07/09/13 11:00 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
I got done with the intake gasket / Hughes Engines plate kit project. Oil pressre switch appeared to be leaking so I replaced it. Engine stareted right up and ran perfect. After a short while idling I noticed that oil pressure was reading zero. I reached in to check the connector and it looks like part of it came off and lower part is still attached to the sensor. How do you fix that? Are replacemnts avalable? Do I need to cut wires or anything like that?
Re: 98 Ram SS/T oil pressre switch connector. [Re: Gabmando] #1465670
07/10/13 10:59 PM
07/10/13 10:59 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
False alarm. Brand new Echlin switch broke in two. Replacement is fine.
