340/904 flexplate #1463802
07/07/13 01:42 AM
07/07/13 01:42 AM
Rockford,IL
71Polara383 Offline OP
Rockford,IL
What flex plate is needed to use a 904 behind an external balance 340? Was gonna build a 360 but plans changed. The converter I bought is for external balance small blocks. Its a boss hog 2800 stall for a 904
Re: 340/904 flexplate [Re: 71Polara383] #1463803
07/07/13 01:46 AM
07/07/13 01:46 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the amount weight for externally balanced 340 and 360 are different...
can not use a externally balanced converter for a 360 on a externally balanced 340....need to knock weights off converter and get B&M weighted flexplate for externally balanced 340.
Tony
70 AARCuda Vitamin C
Re: 340/904 flexplate [Re: 70AARcuda] #1463804
07/07/13 01:49 AM
07/07/13 01:49 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.summitracing.com/parts/bmm-10235/overview/make/dodge
only shows for 727....
what is the bolt circle of the torque converter...
Tony
Re: 340/904 flexplate [Re: 70AARcuda] #1463805
07/07/13 02:17 AM
07/07/13 02:17 AM
Rockford,IL
Rockford,IL
10'' bolt pattern. I can just knock the weight off my converter?
Re: 340/904 flexplate [Re: 71Polara383] #1463806
07/07/13 04:39 AM
07/07/13 04:39 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
That is right - just knock the weight off if you have a internal balanced 340.
Re: 340/904 flexplate [Re: MoparforLife] #1463807
07/07/13 06:29 AM
07/07/13 06:29 AM
Rockford,IL
Rockford,IL
The motor I'm considering is a 72 cast crank 340 with external balance. My 360 is trashed picking up the 340 motor this week hopefully.
Re: 340/904 flexplate [Re: 71Polara383] #1463808
07/07/13 09:41 AM
07/07/13 09:41 AM
Upper Midwest
Upper Midwest
In that case you will need the flexplate for a cast shaft 340 or a converter weighted for a cast shaft 340. BUT if you get the flexplate you will need to take the weights off the present converter as as you cannot use both a weighted converter and flexplated for a cast shaft. And the 360 weighting is different.
