70's truck bodyparts interchange... #1463692
07/06/13 08:58 PM
07/06/13 08:58 PM
abodyman Offline OP
super street
abodyman  Offline OP
super street
Can anyone tell me, if the 1981 Dodge truck hood and windshield cowl interchange with a 1976 ?
Am looking to replace my stock hood with something different than the bathtub type hood.
But don't want to actually buy one, till I know if will fit.
Does the latch install in same spot too?
Can I also use a remote hood release maybe?
Hmmmmm
Oops..see now the 81 hood is the same? so..mid 80's?
Re: 70's truck bodyparts interchange... [Re: abodyman] #1463693
07/06/13 09:37 PM
07/06/13 09:37 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Yes BUT you'll need the wiper transmissions aswell and modify the hood latch(not sure exactly what needs modded) Think the latch just moves over. The wipe transmissions are taller since the cowl panel is raised up. 79-93 use the same hood/cowl
Re: 70's truck bodyparts interchange... [Re: 76dodgeboy] #1463694
07/06/13 10:22 PM
07/06/13 10:22 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
you have to slot the holes & move the latch over
Re: 70's truck bodyparts interchange... [Re: 76dodgeboy] #1463695
07/06/13 10:37 PM
07/06/13 10:37 PM
abodyman Offline OP
super street
abodyman  Offline OP
super street
By "wiper transmissions" You mean the whole complete assembly with motor too? is the only difference in, the height of the studs, sticking out?
Re: 70's truck bodyparts interchange... [Re: BulletBob] #1463696
07/06/13 10:40 PM
07/06/13 10:40 PM
abodyman Offline OP
super street
abodyman  Offline OP
super street
Moving the latch over shouldnt be too much of a problem...hopefully!
I like the newer hood with the 76 grille !
and the remote latch possibility too
Thanks !! for the tips !
Re: 70's truck bodyparts interchange... [Re: abodyman] #1463697
07/06/13 11:14 PM
07/06/13 11:14 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Just the linkages & transmissions not the motor
this only works 75-80
72-74 you have to make the piece that goes to the motor because in those years the wiper motor is in a different position
Re: 70's truck bodyparts interchange... [Re: BulletBob] #1463698
07/06/13 11:54 PM
07/06/13 11:54 PM
abodyman Offline OP
super street
abodyman  Offline OP
super street
Ok I have a 76 D-100 so should be good.
Now another ? if its ok?
Are the earlier hood hinges the same as the later ones? The reason I am asking, is I looked at a foto of a 1985 Truck hood on "row52" and it looks like the hinges may be, smaller?
also, can I use the earlier years fenders instead of the mid 80 ones? or are they exactly the same?
I have NO clue about what fits what and Thank everyone for Your experience and replies !
Re: 70's truck bodyparts interchange... [Re: abodyman] #1463699
07/07/13 12:02 AM
07/07/13 12:02 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Not even the linkage. Transmission is the part the arm hooks to. The part that sticks out of the hole in the cowl. Its 3 bolts. 7/16ths I think
Same hinges
Re: 70's truck bodyparts interchange... [Re: 76dodgeboy] #1463700
07/07/13 12:20 AM
07/07/13 12:20 AM
abodyman Offline OP
super street
abodyman  Offline OP
super street
Ok thats good !! I just replaced the bushings in the linkage arms last year!
I Love doing this kind of stuff !!! making things better with factory parts !!
Re: 70's truck bodyparts interchange... [Re: abodyman] #1463701
07/08/13 06:28 PM
07/08/13 06:28 PM
Pennsylvania
scannman70 Offline
scannman70  Offline
Pennsylvania
So this is the look you are going for. 76 grill and 1980 hood
Re: 70's truck bodyparts interchange... [Re: scannman70] #1463702
07/08/13 07:24 PM
07/08/13 07:24 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You have 81up sheet metal though
Re: 70's truck bodyparts interchange... [Re: 76dodgeboy] #1463703
07/11/13 12:06 AM
07/11/13 12:06 AM
abodyman Offline OP
super street
abodyman  Offline OP
super street
It looks good to Me...
How big a difference is 81 and up sheetmetal?
Re: 70's truck bodyparts interchange... [Re: abodyman] #1463704
07/11/13 01:12 AM
07/11/13 01:12 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Look at the body lines in the fenders and doors..
I am truckless..
Re: 70's truck bodyparts interchange... [Re: 340SHORTY] #1463705
07/11/13 02:39 AM
07/11/13 02:39 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Fenders
