Re: Overheating? 'Tis the season. Read before posting.
[Re: autoxcuda]
#1463518
05/27/14 04:35 PM
05/27/14 04:35 PM
Posts: 27,596 So Cal
autoxcuda
So Cal
Anti Freeze mix itself only raises the boiling point 13 degrees at a 50/50 mix. And only 8 degrees at 30% mix.
Your radiator pressure cap that raises the boiling point 48 degrees with a 16 lbs radiator cap.
Check your radiator cap performance and system for pressure leaks! Much more important in regards to overheating than anti freeze.
[Re: autoxcuda]
#1463519
05/27/14 04:50 PM
05/27/14 04:50 PM
autoxcuda
So Cal
The heat capacity is basically how much heat energy the coolant can carry out of the engine and to the radiator.
As far as carrying heat goes, water does a really good job. It’s actually one of the most effective coolants that could possibly be used.
The specific heat capacity of ethylene glycol is only about 65% of water at the temperatures seen in a cooling system.
[Re: autoxcuda]
#1463520
05/27/14 05:51 PM
05/27/14 05:51 PM
autoxcuda
So Cal
If you choose to run staight water to get a little extra help in cooling. Use water without the minerals. Like Reverse Osmosis or Distilled. Then run a cooling system addtive that reduces electrolysis, anti corrosion, reduces surface tension, neutualizes pH. All additive will reduce the boiling point some too as they car chemical solutes in the waters (8th grade chemistry) Here's a very throrough performance test of cooling system additives: http://www.turbomagazine.com/features/0703_turp_cooling_system_additives/viewall.htmlTable of results:
[Re: autoxcuda]
#1463521
05/27/14 06:13 PM
05/27/14 06:13 PM
Posts: 28,114 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You were the one who had something going with the Justice Brothers, weren't you?
[Re: feets]
#1797235
04/07/15 10:50 AM
04/07/15 10:50 AM
feets
Senior Management
Senior Management
Irving, TX
Bumping this to the top again for the 2015 overheating season.
[Re: feets]
#2679070
07/19/19 11:15 AM
07/19/19 11:15 AM
feets
Senior Management
Senior Management
Irving, TX
People are still overheating in 2019.
[Re: 70Cuda383]
#2679146
07/19/19 03:12 PM
07/19/19 03:12 PM
Posts: 28,730 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
My 69 VW Bug keeps overheating, should I flush my radiator? <img src="/ubbthreads/images/graemlins/hammer.gif" alt="" />
great post kevin. I used a pump from a Super Beetle it has a Large S on the front and RED CAPE
