Adapting a 440 MSD Distributor to a 400 Block? #1463122
07/05/13 03:10 PM
07/05/13 03:10 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Does anyone make a spacer/adapter to run a tall deck MSD distributor in a low deck block? I was thinking the extra height might be nice when running the cap-adapt that utilizes the larger ford style distributor cap.
Thoughts?
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: Jeremiah] #1463123
07/05/13 03:15 PM
07/05/13 03:15 PM
AndyF Online content
AndyF  Online Content
That is kind of a trick question.
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: Jeremiah] #1463124
07/05/13 03:18 PM
07/05/13 03:18 PM
Boise
Moparteacher Offline
Boise
I have a MSD dizzy in a 383 block. I used a Mopar spacer, but the spacer ID was turned down to fit the large MSD base.
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: AndyF] #1463125
07/05/13 03:42 PM
07/05/13 03:42 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Now I am confused....can you elaborate on that sir?
I was hoping to gain some height using a 440 distributor in a 400 block with a spacer. Am I missing something here (like usual)?
Moparteacher - I will keep that in mind. I think the spacers are still around for sale...
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: Jeremiah] #1463126
07/05/13 04:19 PM
07/05/13 04:19 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
ok i am completely confused. (not unusual )
i think this is what you are looking for
http://chucker54.stores.yahoo.net/rbtobbldiad.html
Joe
Without Data, you’re just another guy with an opinion.
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: sr4440] #1463127
07/05/13 04:30 PM
07/05/13 04:30 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Joe
That is exactly what I am looking for. I did not realize one was being made. Thank you!
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: Jeremiah] #1463128
07/05/13 08:41 PM
07/05/13 08:41 PM
It is a trick question because Mopar Performance has been making RB to B distributor adapters for 40 years. The trick part of the question is that those adapters do not fit a MSD distributor.
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: AndyF] #1463129
07/05/13 09:30 PM
07/05/13 09:30 PM
Delray beach, Florida
P
Performance Only Offline
P
Billet adapter kit works with MSD 8546 Billet distributors.
$64.95
MRE90275MSD
machine shop owner and engine builder
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: Performance Only] #1463130
07/08/13 02:42 AM
07/08/13 02:42 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Perfect, thank you Dan!
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: AndyF] #1463131
07/25/13 02:57 AM
07/25/13 02:57 AM
NW INDIANA
ta3834bbl Offline
ta3834bbl  Offline
NW INDIANA
What is different about the MSD dist that it won't fit? I have been using a 440 dist in my 383 for 25 years and was thinking about upgrading to an MSD. now I'm confused....
67 Dart GT Convertible 273
68 Barracuda 383
68 Roadrunner 383 4spd
1 '01 Ram 2500 4x4 diesel
2 '02 Rams 1500 4x4's 4.7s
3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4
Oh, and a 03 Grand Cherokee and an '00 durango smile
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: ta3834bbl] #1463132
07/25/13 07:53 AM
07/25/13 07:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The MSD distributor has a bearing in the housing at both ends of the shaft so it is larger , all you need to do is have the ID of the adapter opened up , 10 mins on a lathe , if that long .
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: Jeremiah] #1463133
07/25/13 10:25 AM
07/25/13 10:25 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
If running an N96 air grabber, suggest you check its clearance...
Just my $0.02...
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: ta3834bbl] #1463134
07/25/13 11:15 AM
07/25/13 11:15 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I am going to use the taller RB distributor in a B (in this case 400) block to gain more clearance between the cap and passenger side valve cover. Hope that makes sense.
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: Sinitro] #1463135
07/25/13 11:19 AM
07/25/13 11:19 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Just my $0.02...
I appreciate the tip. My "air grabber" is two 1050's and an Indy tunnel ram.
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: Jeremiah] #1463136
07/25/13 01:14 PM
07/25/13 01:14 PM
NW INDIANA
ta3834bbl Offline
ta3834bbl  Offline
NW INDIANA
Thanks, I got that part, doing the same thing ( 440 dist in a 383 ) , I was confused about the msd not fitting in my old adapter . I am with the program now
68 Barracuda 383
Re: Adapting a 440 MSD Distributor to a 400 Block? [Re: JohnRR] #1463137
07/25/13 01:26 PM
07/25/13 01:26 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
That is correct. While it's on the lathe have it cut for a O ring also so it seals. Thanks to HEMI Joel for turning mine down.
