Re: Two brake questions:
[Re: GregY]
#146312
11/05/08 11:11 PM
11/05/08 11:11 PM
RapidRobert
that is pretty much normal drum brake fade & cheaper linings contribute to that & a problem issue with bleeding is having the bleeder screws not closed enough when your helper releases the brake pedal & air gets sucked back in past the threads & being sure the MC is bled(on or off the car) 1st.
