'05 Cummins Tans doing something weird. #1462258
07/03/13 02:37 PM
07/03/13 02:37 PM
Charlotte, NC
Orange_Crush Offline OP
Belieber!
Belieber!
Charlotte, NC
I can't seem to find anything on this anywhere, hoping y'all can help me out.
I have a 2005 Ram 3500 5.9 Cummins with the 48RFE transmission. Occasionally, the transmission temp warning light on the dash comes on.
Here is the thing. It only flashes on for a second and pings and then turns off again. I have pulled over and done the finger check on the transmission fluid and its always BARELY lukewarm, never hot, and, as I said, the light never stays on, it just flashes on and off.
It doesn't do it every day maybe every week or so and it will do it 2 or 3 times during my 30 mile commute. But then it doesn't do it again for days or weeks at a time.
Could the problem be a bad sender?
1970 Dodge Charger R/T Hemi Orange U-code 4-speed
1971 Jaguar E-Type Series 3 V-12 4-speed 2+2 Signal Red.
Re: '05 Cummins Tans doing something weird. [Re: Orange_Crush] #1462259
07/03/13 11:07 PM
07/03/13 11:07 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
you have a 48re in that and the trans temp sensor is part of the transducer inside the pan it could be going bad they give a lot of problems.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: '05 Cummins Tans doing something weird. [Re: dusturbd340W5] #1462260
07/04/13 01:04 PM
07/04/13 01:04 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Put a governor pressure transducer in it.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: '05 Cummins Tans doing something weird. [Re: 71yelladustr] #1462261
07/10/13 10:14 AM
07/10/13 10:14 AM
Charlotte, NC
Belieber!
Belieber!
Charlotte, NC
Bought a heavier duty Borg Warner solenoid unit and new transducer and installed them yesterday...problem solved (along with a weird "hesitation" on initial acceleration). Trans is now working perfectly! Thanks for the help.
Re: '05 Cummins Tans doing something weird. [Re: Orange_Crush] #1462262
07/10/13 08:10 PM
07/10/13 08:10 PM
Kissimmee Fl.
Kissimmee Fl.
that borg-warner unit is a great upgrade
