Best Challenger Shaker Repro? #1460245
06/30/13 01:00 PM
06/30/13 01:00 PM
Long Island, NY
Jstern Offline OP
Jstern  Offline OP
Long Island, NY
I would like to pick up a repro shaker hood at Carlise. Does anyone make a repro aside from AMD (Goodmark?)? If so, what is the consensus on the best repro hood out there?
I tried searching this but was getting overwhelmed with the results. Thanks!
Re: Best Challenger Shaker Repro? [Re: Jstern] #1460246
06/30/13 01:16 PM
06/30/13 01:16 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
It depends on the definition of 'best'.
The most accurate reproductions are made using a Harms kit, available at RestoRick. You will need a clean, flat hood as a donor and expect to do some welding and metalwork.
For a hood ready to go, the AMD is a very nice piece and would be a top choice for a non-N96 car
Gean Gregory makes a decent repro from original hoods, but there are significant differences in the underbracing and the weld patterns vs original
Art at SixPack performance usually has a few of his hoods available on row 'L', and Art is a good guy to deal with
Northwest Performance/Ben Snobar makes an affordable DIY shaker kit but it does require lots of work to get right. Particularly the trim ring
If your car is an original shaker car, and the budget doesn't permit an original Challenger shaker, then the Harms kit would be top recommendation for closest to factory
If you're adding the option, the AMD hood can't be beat for the $$$
Re: Best Challenger Shaker Repro? [Re: Jstern] #1460247
06/30/13 01:41 PM
06/30/13 01:41 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The only full, quality REPRO hood on the market is the AMD piece, the downside to using one of the conversion kits, is finding a nice clean, rustfree, non pitted original hood
Re: Best Challenger Shaker Repro? [Re: DAYCLONA] #1460248
06/30/13 02:54 PM
06/30/13 02:54 PM
Long Island, NY
Jstern Offline OP
Jstern  Offline OP
Long Island, NY
It's an original n96 car. I have the harms kit and a clean donor hood, but wasn't sure it was worth the effort using that with the repro options available.
Do you guys know anyone who does the conversions in the north east? I don't want to take on that project myself or give it to someone inexperienced to do.
Re: Best Challenger Shaker Repro? [Re: Jstern] #1460249
06/30/13 03:14 PM
06/30/13 03:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Ron Johnson has done the conversions with the Harms kits in the past, you might try him. If you want a factory looking under brace structure the Harms kit (now available through www.restorick.com) is the ONLY accurate design on the market other than an original hood, kit, complete hood, or otherwise.
Re: Best Challenger Shaker Repro? [Re: Jstern] #1460250
06/30/13 05:09 PM
06/30/13 05:09 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If you have the conversion kit and a clean hood, then it's a no brainer, if you don't want to tackle the job yourself, then the only one "close" to you would be Russ Jacobs at RJCARS in Arkport NY 6073248325...your probably better off shipping him the set up seeing your in Long Island, Russ is in the upper west end of the state
....But you have to ask yourself if it's worth it? your going to drop at least a G note to farm the job out, plus close to $500+ (NY is outrageous for shipping DAMHIK) if you have to ship it both ways....An AMD hood delivered is approx $1200, or $900 if you do a Carlisle pick up
...depending on when you bought the conversion kit, you may have spent anywhere from $300 to $800, plus the cost of the donor hood, so either keep dumping money on the conversion kit, or buy an AMD hood and sell off the kit hood project to recoup some cash?...depends on you and the level of your project
Re: Best Challenger Shaker Repro? [Re: DAYCLONA] #1460251
06/30/13 05:15 PM
06/30/13 05:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
.....And not correct in the (obvious to any knowledgeable observer) details, something that matters to most owners of an original N96 car.
Personally I'd skip all of the above for a real N96 car and seek out and buy a real one, even if it ended up being a long search and big money.
Re: Best Challenger Shaker Repro? [Re: ScottSmith_Harms] #1460252
06/30/13 06:44 PM
06/30/13 06:44 PM
YYZ Offline
YYZ  Offline
This is the route that I've gone for mine, after having had experience with all of the above options. Mine is an OEM hood that will need some tricky repair in places, but I lucked into a very skilled metal craftsman that will make it perfect.
FWIW there were a few original Challenger shaker hoods for sale at Carlisle last year ranging from obvious junk to those looking shiny and good. But without seeing the hood in bare metal or close to it, Challenger hoods can hold nasty surprises -- particularly in the nose section.
Re: Best Challenger Shaker Repro? [Re: YYZ] #1460253
06/30/13 08:29 PM
06/30/13 08:29 PM
Long Island, NY
Jstern Offline OP
Jstern  Offline OP
Long Island, NY
Thanks for the input. I think I will dust off the kit & the donor hood and take another look at it. Of course, I'd love to get a real hood for the car, but I've yet to stumble on one priced in my range.
Re: Best Challenger Shaker Repro? [Re: Jstern] #1460254
07/01/13 11:20 AM
07/01/13 11:20 AM
New York, Chautauqua county
mightycuda Offline
mightycuda  Offline
See Art Pacheco at Carlisle, he has shaker hoods by Gene Gregory and all the goodies. Six Pack Performance is at row L spaces 101 to 105. Art is a great guy and has excellent pieces.
Re: Best Challenger Shaker Repro? [Re: mightycuda] #1460255
07/01/13 11:34 AM
07/01/13 11:34 AM
YYZ Offline
YYZ  Offline
Here is an example of what you can find after having a Challenger shaker hood stripped.
This hood was clean and relatively undamaged in the nose section (usually very vulnerable to rust and/or collision damage). However, per the photo someone has attempted to reattach an original shaker underbrace by both brazing it and beating the living daylights out of it.
With paint on it, there was no indication of the horrors underneath. So be careful before you drop $2K or more on an original.
Suffice it to say, I won't be using this hood....
