8.75 gear lube? #145980
11/05/08 10:22 AM
11/05/08 10:22 AM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
with todays high tech lubes on market do they offer a light/w lube for the 8.75 clutch type suregrips or do i stay the old 80-90/w with the suregrip additives?
Re: 8.75 gear lube? [Re: Lew] #145981
11/05/08 10:35 AM
11/05/08 10:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I still run the old lube with additive.Its worked for 40 years.Rocky
Chrysler Firepower
Re: 8.75 gear lube? [Re: Lew] #145982
11/05/08 11:01 AM
11/05/08 11:01 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I generally subscribe to the " If it ain't broke, don't fix it theory". I use conventional 80-90 gear oil with limited slip additive. I used a NAPA additive, I think the brand name was X-Track or something like that. It's a good idea to use the additive as an assembly lube when putting the sure-grip unit together.
Re: 8.75 gear lube? [Re: 5spdcuda] #145983
11/05/08 02:20 PM
11/05/08 02:20 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I put amsoil synthetic in mind and it already has
the friction modifier in it. No chatter here.
Re: 8.75 gear lube? [Re: therocks] #145984
11/05/08 02:31 PM
11/05/08 02:31 PM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
If ONLY they still had it available !! There was an EMPTY can of this that sold on eBay for 25$ or so some time ago !!!
The last time I picked up a SG pig at the JY ...I drained and SAVED the lube ... very VERY stinky skunk-oil ! I still have it to use in my next project.
But the closest I have seen to that old-lube is Mobil-1 syn gear-lube.
Re: 8.75 gear lube? [Re: IcorkSOAK] #145985
11/05/08 03:44 PM
11/05/08 03:44 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I have gotten sure grip/posi additive at either NAPA or Carquest.
Re: 8.75 gear lube? [Re: IcorkSOAK] #145986
11/05/08 04:07 PM
11/05/08 04:07 PM
that's funny
Re: 8.75 gear lube? [Re: RapidRobert] #145987
11/05/08 11:46 PM
11/05/08 11:46 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
that's funny
THIS is one of the oddest auctions on eBay I have ever seen. It was clearly advertised as empty ...and from the pic ... looked VERY sharp and clean.
??... Maybe he just wanted to crack-open the can once a month and get a good wiff of that SKUNK-oil.
Re: 8.75 gear lube? [Re: Lew] #145988
11/05/08 11:49 PM
11/05/08 11:49 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I wouldn't recommend sythetics in a limited slip,yes, I'm very aware the factory diffs often are.
