Anyone ever seen a 4x4 with 2:94 gears? #1459009
06/27/13 03:30 PM
06/27/13 03:30 PM
Winnipeg, Manitoba, Canada
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
The 82 truck I'm driving came from the factory with 2:94 gears and 10" rear brakes. I don't know what they were thinking when they ordered that truck. It's got an auto trans and I have to drive it in 2nd gear when I'm in the city and that's with 30" tires.
Re: Anyone ever seen a 4x4 with 2:94 gears? [Re: 4dr4x4] #1459010
06/27/13 03:48 PM
06/27/13 03:48 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Yep had a 79/80 Parts truck that had them. What tire size does the tag say? I think its probably one that calls for 195/75 15s
Re: Anyone ever seen a 4x4 with 2:94 gears? [Re: 4dr4x4] #1459011
06/27/13 03:58 PM
06/27/13 03:58 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
I never thought to look at what size tires it came with, I will let you know.
Re: Anyone ever seen a 4x4 with 2:94 gears? [Re: 4dr4x4] #1459012
06/27/13 04:25 PM
06/27/13 04:25 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I think the one I had called for 195s if not that one I know one did cause I was like WTF considering 31s also came stock and on a Fullsize 4wd
Re: Anyone ever seen a 4x4 with 2:94 gears? [Re: 4dr4x4] #1459013
06/28/13 12:25 AM
06/28/13 12:25 AM
Waynesboro PA 17268
RODHALL Offline
RODHALL  Offline
Waynesboro PA 17268
yes I parted out a 4x with 2.94 gears.....
Had a 88 3/4 4x4 with a cummins that had 3.08 gears... it was not a bad truck....
Re: Anyone ever seen a 4x4 with 2:94 gears? [Re: 76dodgeboy] #1459014
06/28/13 12:28 AM
06/28/13 12:28 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I bought a RC that had 2.94's front & rear with 31's on Turbine wheels
Re: Anyone ever seen a 4x4 with 2:94 gears? [Re: BulletBob] #1459015
06/28/13 03:06 AM
06/28/13 03:06 AM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
All I can say is it's great on the hi way, not much over idle at 60.lol
Re: Anyone ever seen a 4x4 with 2:94 gears? [Re: 4dr4x4] #1459016
06/30/13 07:31 PM
06/30/13 07:31 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
My '82 Ramcharger has 2.94s.
It's Swifty! Swifty, you toad sucker!
