'69 402 Oil Pan - Which Pickup ? #1458160
06/25/13 03:47 PM
06/25/13 03:47 PM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
Hi all, My '69 440 has the "402" stamped oil pan with baffles. I'm confused as to which is the correct pickup to order. The MoPar catalog lists a P4529565 as a 6 qt 3/8 pipe RB engine but also lists a P5007848 6 qt 3/8 pipe use with Oil Pan P5007807AB which is described as a 5 qt center sump stock style. Um... help, LOL Thanks, Mike
Re: '69 402 Oil Pan - Which Pickup ? [Re: MCTPhoenix] #1458161
06/25/13 06:07 PM
06/25/13 06:07 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Someone at MP changed the pickup descriptions and they are WRONG for the most part, the 565 pickup is not for a 383 with 6qt pan because that pan was never installed on a 383, the 565 pickup is the one to use with the hemi pan in any block that uses a 3/8 pickup tube.
the pickup you want is P4529564 ...
Incidentally this exact question has been answered numerous times over the years , using the google search tab at the top of the page would have come up with it .
Re: '69 402 Oil Pan - Which Pickup ? [Re: JohnRR] #1458162
06/26/13 06:33 PM
06/26/13 06:33 PM
Phoenix, AZ
Phoenix, AZ
Not surprised the descriptions are changed/incorrect. At SEMA last year the Mopar display had small block valve covers under a sign that said Big Block. LOL Thanks, I'll try to locate the #564 pickup. That's supposed to be the one with the "U" tube instead of the straight tube correct?
Re: '69 402 Oil Pan - Which Pickup ? [Re: MCTPhoenix] #1458163
06/26/13 08:31 PM
06/26/13 08:31 PM
JohnRR Offline
JohnRR  Offline
yes bent tube , check summit , cheapest price when I was buying them
