Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456218
06/25/13 07:00 AM
06/25/13 07:00 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Domingo unless that clearance has been there all along (oversize from machine shop) a bigger lifter wouldn't be the way to go. I assume that is wear and if so the bore will not be round.
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456219
06/25/13 10:48 AM
06/25/13 10:48 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
But if I can stick a feeler gauge thats 0,0025" in there common sense tells me that actual clearance is even more than that
My first thought. It sounds like re-bushing would be the most cost effective fix.
Re: Can u get a solid roller lifter that's a true ,904"? [Re: tubtar] #1456220
06/25/13 10:57 AM
06/25/13 10:57 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Its not wear, the engine has been run for a very short period. those bushings are fresh.
I will re-bush and add oiling holes.
A true ,904" lifter is not cost effective from what I have seen.
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456221
06/25/13 10:59 AM
06/25/13 10:59 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
thanks for all the replies!
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456222
06/25/13 12:44 PM
06/25/13 12:44 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Maybe it slipped by.. but lifters need the clearance.
Not sure what the factory recommends but Jesel says.... http://www.jesel.com/innovation/lifters/bushings-and-retainers.html
and... http://www.dartheads.com/dartboard/archive/index.php/t-2429.html
Get and accurate measurement and then decide
Re: Can u get a solid roller lifter that's a true ,904"? [Re: 52savoy] #1456223
06/25/13 02:16 PM
06/25/13 02:16 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Jesel reccomends 0.002"
My lifters are defintely too loose in those lifter bores. If that feeler gauge fits in between the lifter body and bushing I'm guessing I got 0.003" clearance at least. Im pulling the trigger and replacing them all, and incorporating a lubrication hole as well....
thanks for the replies guys!
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456224
06/25/13 03:17 PM
06/25/13 03:17 PM
