tranny or touque? #1455888
06/21/13 12:55 AM
06/21/13 12:55 AM
bc canada
67valiant Offline OP
bc canada
kinda lost on this so i ask car sgifts fine when in burn out box but when i lauch its good shift into 2 rpm drops like maybe 500rpm then shift into drive drops like it should stall is a 5000 so tranny slip or convertor slippage? you can here it shift when i was videoed but in the box and going down the strip any ideas?
Re: tranny or touque? [Re: 67valiant] #1455889
06/21/13 08:35 AM
06/21/13 08:35 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
So given the information given, what do you think should be happening? Why do you think some thing is slipping? Do you think the rpm's should stay the same , more drop,less drop? I don't know why I responded , never race with a a automatic.
Re: tranny or touque? [Re: rowin4] #1455890
06/21/13 07:55 PM
06/21/13 07:55 PM
bc canada
bc canada
you would think it would drop in rpm or am I missing something it drop when it hits 3rd but not a lot from 1-2
Re: tranny or touque? [Re: 67valiant] #1455891
06/21/13 08:01 PM
06/21/13 08:01 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
If it is revving too much in 2nd then your band is loose or worn out. Try tightening it up all the way and then backing off 2 turns.
Re: tranny or touque? [Re: cgall] #1455892
06/22/13 01:21 PM
06/22/13 01:21 PM
bc canada
bc canada
i was wondering about that but now what band the low reverse or the one you can get to on the outside that one is high band if i recall
