Is that a gasket on the back of the torque cover plate? #1454608
06/17/13 09:40 PM
06/17/13 09:40 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Looks like the remains of a small gasket near the starter on the back of my torque converter cover plate? Was that there to protect from dirt, water?
Re: Is that a gasket on the back of the torque cover plate? [Re: cudabitten] #1454609
06/17/13 09:51 PM
06/17/13 09:51 PM
What year car, motor and trans? Some of the early BB motors came with spacers bewteen the starter and the 727 beallhousing as well as the torque converter dust sheild, not sure about the SB
Re: Is that a gasket on the back of the torque cover plate? [Re: Cab_Burge] #1454610
06/17/13 09:56 PM
06/17/13 09:56 PM
eastern, pa.
eastern, pa.
Just a 74 small block barracuda. There is definately something in the shape of a half moon right next to the starter that looks to be machine cut and will not come off easy, looks sort of yellow. Just curious if should have installed some double sided tape or something.
Re: Is that a gasket on the back of the torque cover plate? [Re: cudabitten] #1454611
06/17/13 10:29 PM
06/17/13 10:29 PM
Sturgis S.D.
tripleblackcuda Offline
Sturgis S.D.
Probably someone put some double sided tape or gasket stuff in there. I have never seen a gasket located there before.
Re: Is that a gasket on the back of the torque cover plate? [Re: tripleblackcuda] #1454612
06/18/13 05:11 AM
06/18/13 05:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Is that a gasket on the back of the torque cover plate? [Re: JohnRR] #1454613
06/18/13 08:06 AM
06/18/13 08:06 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I saw a thin foam type gasket between some of them.It looks almost like the foam gasket they used on the front dust shields.Since the 60s Ive pulled quite a few and some had it some didnt.Rocky
Chrysler Firepower
Re: Is that a gasket on the back of the torque cover plate? [Re: therocks] #1454614
06/18/13 08:12 AM
06/18/13 08:12 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
That would be correct !!
Re: Is that a gasket on the back of the torque cover plate? [Re: 62maxwgn] #1454615
06/18/13 08:50 AM
06/18/13 08:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
62 its been a lot of years but I was sure I saw them.Just glad Im not getting really Senile.Rocky
Chrysler Firepower
Re: Is that a gasket on the back of the torque cover plate? [Re: therocks] #1454616
06/18/13 09:00 AM
06/18/13 09:00 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I'm getting a little senile but still remember a few things !
Re: Is that a gasket on the back of the torque cover plate? [Re: 62maxwgn] #1454617
06/18/13 10:00 AM
06/18/13 10:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I knew as soon as I got in on this that there would be posts to the contrary ...
Re: Is that a gasket on the back of the torque cover plate? [Re: JohnRR] #1454618
06/18/13 10:54 AM
06/18/13 10:54 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
IIRC it was on the thin piece that sat behind the starter.Its been years since Ive torn down an untouched one.I have a 68 SB motor trans combo that is sitting under the bench thats never been apart.I might just have to pull the starter.Rocky
Chrysler Firepower
Re: Is that a gasket on the back of the torque cover plate? [Re: JohnRR] #1454619
06/18/13 09:25 PM
06/18/13 09:25 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you were older you would have known !!
