Re: Opinions on rocker arm failure.
[Re: B Dartman]
#1454053
06/18/13 10:09 AM
06/18/13 10:09 AM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
I would be looking for all the aluminum,and where it went....pull the pan,if not engine to inspect,imho.
Agree. Unfortunately last summer I had a lifter on its way to failure (flat tappet with little to no load) and the bottom of the lifter became concave the associated cam lobe had begun to wear down too. Wear was minimal but took the approach mentioned above and ended up finding metallic residue from cam and lifter on the windage tray and scoring in the oil pump (that metal all has to go somewhere). Went ahead and turned a cam swap into an overhaul.
Hope you get it all sorted out and back in working order!
On the piston skirts also below the offending lobe.
[Re: JohnRR]
#1454054
06/18/13 04:27 PM
06/18/13 04:27 PM
Posts: 2,177 ill
dennismopar73
ill
Shoot just spray wash it off with some cleaner, put new rockers on run it!!!!!!! LOL I could not do it but maybe you can get by!!!?????LOL
[Re: dennismopar73]
#1454055
06/18/13 05:46 PM
06/18/13 05:46 PM
JohnRR
A gulag near you.
That's what most people do
[Re: dvw]
#1454059
06/19/13 10:25 AM
06/19/13 10:25 AM
JohnRR
A gulag near you.
For what its worth my swap meet small block aluminum rockers have shaft grooves that extend beyond the rockers. They are not mounted in blocks. 145 on the seat 340 open. Doug
When is the last time you took them apart and inspected them? I wouldn't think that the grooves should be extending past the rockers.
[Re: Thumperdart]
#1454061
06/19/13 12:19 PM
06/19/13 12:19 PM
Posts: 3,511 DFW
mr_340
DFW
The rockers appear to have gotten really hot. From what I've seen on Matweb, the tensile strength of aluminum drops off pretty fast with increasing temperature. That will explain the failure of the bore. Any aluminum rocker will do that with that amount of heat. The hard chromed shafts might help with the galling problem. I think I'd replace all the rockers and shafts and maybe keep some of those that look OK as spares.
Floyd Lippencott IV
[Re: MR_P_BODY]
#1454064
06/19/13 04:51 PM
06/19/13 04:51 PM
Posts: 2,177 ill
dennismopar73
ill
I have yet to see a motor not needing a complete gone through ,or the need of replacing parts after damage from lifters / rockers, . I have seen 2 of my motors that lost a comp cam after 8 passes needing what apeared to be complete rebuild ! piston skirts had unbelievable damage from the particules as well as oil pump, and crank having to b e returned ! after 8 passes! the amount of trash just falling onto the rotating assembly . I have seen a couple racer just reclean the motors reassemble but the motor does not live long! those small particules really get in everywhere! the oil filter does not can not, will not filter all the oil in the system . impossable! no filter can! do your self a favor take motor out, tear it down replace everything with wear, damage ! do not trust anything ! unless you are happy with it,, or the engine builder is !
[Re: Azzkikrcuda]
#1454066
06/20/13 11:25 AM
06/20/13 11:25 AM
Posts: 7,506 Az
Crizila
Az
If I would have found anything installed wrong or out of spec. there would have been no reason to post anything, I would have had my answer. But, since everything checked out OK, about the only thing that sounds plausible is the damage started from the shaft grooves. Whether it was from a burr, lack of lube at start-up because it sits for long periods between driving, grooves too long or a combination of these. Probably can't be determined at this point.
Not saying you don't or could have caught this problem, but inspection maintenance on any " high performance" motor that you beat on regularly should be OFTEN. With todays aggressive cam profiles and accompanying high spring pressures, valve train should be looked at very often. My routine is every 10 to 12 passes down the track the valve covers come off. Besides running the valves, I pay special attention to the rockers, retainers, keepers, springs, and look for any metal around the spring pockets in the heads. All the plugs come out and I look at them closely for heat issues, coloration, metal specs on the porcelain, etc. About every second or third inspection I run a compression check. Since Dec of 2012 ( approx. when motor was built ) I have done 7 compression checks. I have a great history since motor was new, so I have a good idea what is going on inside the motor. Same thing with oil pressure readings. I know what the norm is hot / cold and mark my gauge accordingly. It's all time consuming and boring, but I believe it can pay off if you can catch a failure in progress.
Fastest 300
[Re: JohnRR]
#1454067
06/20/13 05:46 PM
06/20/13 05:46 PM
Posts: 9,982 MI, usa
dvw
MI, usa
I ran iron rockers on home grooved shafts that extended beyond the rockers for years (10+). To be honest with these I probably have checked lash once a year. This year I haven't even run the car do to running the new car. I've never had lash move more than.001". I feel pretty confident with no lash change that they are fine. Doug
[Re: dvw]
#1454071
06/23/13 08:40 PM
06/23/13 08:40 PM
JohnRR
A gulag near you.
Well I guess that cutting grooves too far doesn't seem to be the issue here or an issue at all ?????
