Re: BRAKE Upgrade
[Re: MaxHeadroom]
#1452815
06/14/13 10:26 AM
06/14/13 10:26 AM
RapidRobert
a suggestion would be to switch to Ceramic pads/shoes then do a bed in (breakin) procedure.
Re: BRAKE Upgrade
[Re: RapidRobert]
#1452816
06/14/13 01:45 PM
06/14/13 01:45 PM
Posts: 145 North East
MaxHeadroom
North East
Thanks, I usually do that with these type of cars. Most likely problem is these are old style. Hoping maybe someone can recommend a brand of vented rotors that will fit 14" that they have used with good results.
Re: BRAKE Upgrade
[Re: MaxHeadroom]
#1452817
06/14/13 02:15 PM
06/14/13 02:15 PM
Posts: 22,715 Bitopia
jcc
Bitopia
Not clear to me, you have currently drums or disc up front? 14" wheel Disc options are rather limited performance wise, but still an improvement over drums. No need IMO to change anything in rear unless repeated high speed stops are anticipated, and then discs in rear would help the small 14" wheel discs in front. A little more info would be helpful.
Re: BRAKE Upgrade
[Re: jcc]
#1452818
06/14/13 03:19 PM
06/14/13 03:19 PM
MaxHeadroom
North East
Got stock setup, PDB front, drum rear. Using 14" stock tires. Want to keep stock look, so cannot change booster or tires. Only option is maybe better rotors? Just asking around what other may have used to get better stopping power. Seems to fade after driving awhile. Everything on there now is new, including lines. Looking for suggestions
Re: BRAKE Upgrade
[Re: edl]
#1452820
06/15/13 08:37 AM
06/15/13 08:37 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
If you have ceramic pads and they fade you have a problem.I run stock Mopar discs on my 65 from a later Mopar.The ceramic pads work great.They never fade even at 120.I believe Brembo makes or made slotted rotors.I run stock type rotors and it street driven also.Rocky
Chrysler Firepower
