Cleaning and protecting old weatherstrip? #1451949
06/12/13 10:17 PM
06/12/13 10:17 PM
Houston, Texas
Slant6pak Offline OP
Houston, Texas
Quick question guys,
How do you like to clean and care for old weatherstripping? In this case the seals in question on not available new... have not been for years.
I was lucky and scored a set in pretty good shape... how should I clean them and "feed" them so the do not dry out and crack?
Also, one piece has two small tears... is there any way to glue them with a glue that will stay pliable?
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: Cleaning and protecting old weatherstrip? [Re: Slant6pak] #1451950
06/15/13 10:01 AM
06/15/13 10:01 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I clean with dilute simple green and then treat with one grand
As far as gluing I think it depends on what is broken. If it's a hollow foam door seal type thing vs. a window seal each would be different.
Products that come to mind could be silicone, contact cement, weatherstrip adheasive.
