70 Cuda Go WIng Mounting Pictures/Info #145166
11/03/08 04:10 PM
11/03/08 04:10 PM
Mount Airy, Maryland
scrag Offline OP
scrag  Offline OP
Could someone post/send me a picture of how the brackets under the trunk lid are mounted (screws or rivets). I can't get a decent print out from the Year 1 catalog so I can't tell - just wanted to see how it was supposed to be done. I am also assuming that you fasten first to the bottom of the actual trunk sheet metal - install brackets and fasten to that next...
Re: 70 Cuda Go WIng Mounting Pictures/Info [Re: scrag] #145167
11/03/08 07:19 PM
11/03/08 07:19 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
You're correct the wing has nuts for the decklid sheetmetal and also adjustment sleeves through the bracket{which go on the wing studs before the bracket is installed} then locknuts.... The brackets are screwed on...Here's best the pic I have...Hopefully someone will have a close-up..
Re: 70 Cuda Go WIng Mounting Pictures/Info [Re: screamindriver] #145168
11/03/08 08:23 PM
11/03/08 08:23 PM
New Jersey Bergen
rjadart Offline
rjadart  Offline
New Jersey Bergen
Go to Mopar Muscle mag site has complete instruction and picts
Re: 70 Cuda Go WIng Mounting Pictures/Info [Re: rjadart] #145169
11/04/08 12:25 AM
11/04/08 12:25 AM
scrag Offline OP
scrag  Offline OP
I went and all I found was this reference:
Go-Wing Install: Just Wing It! October 2004
Not sure if they have a tech archive or not.
Re: 70 Cuda Go WIng Mounting Pictures/Info [Re: scrag] #145170
11/04/08 12:41 AM
11/04/08 12:41 AM
scrag Offline OP
scrag  Offline OP
I found this which is what you maybe refering to:
http://www.fpap.com/cat_uploads/GET-SPOILED.pdf
Re: 70 Cuda Go WIng Mounting Pictures/Info [Re: scrag] #145171
11/04/08 02:54 AM
11/04/08 02:54 AM
808CUDA Offline
808CUDA  Offline
Scott! Your back in town?!?!? You should have called me, I could help you out with that wing install.
Colin is the man with his gorgeous red Cuda. You couldn't have asked for a better colored Cuda pic, huh?
Gil
