Re: Holley 800 metering block
[Re: BradH]
#1449008
06/07/13 07:50 PM
06/07/13 07:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I think that's what the OP looked at when he stated "...Holley book (only says "not serviced")...".
Well I have Holley books also and they dont show those numbers ![](/ubbthreads/images/graemlins/wave.gif)
[Re: topside]
#1449011
06/07/13 09:27 PM
06/07/13 09:27 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
There used to be another holly site that I really liked. I found a number for someone 2 weeks ago and when I went to it this week its gone. I can't tell you how many times I used that site. I will dig into it after a good shower and see if I can relocate it.
[Re: topside]
#1449013
06/07/13 09:56 PM
06/07/13 09:56 PM
MR_P_BODY
For the 4780 and the -1 and -2 they show N/S but for the 4780-3 they show 34R11196AQ as the primary plate... I would need to look up the main body numbers to see if the main body is different... if it isnt then the -3 shown should work(it shows the same pri plate for the -3 through -7) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1449014
06/07/13 10:07 PM
06/07/13 10:07 PM
MR_P_BODY
At loking at the main body it looks like the -4 will work... the first in the numbers is the 4780 and the last line is the 4780 -4... the -3 had some minor change with a suffix change but the -4 is the same as the -2 N/S 1-3/8 1-7/16 1-11/16 1-11/16 0.031 108-83-2 108-89-2 108-83-2 108-89-2 N/R 134-103 134-104 12R11090AP 1-3/8 1-7/16 1-11/16 1-11/16 0.031 108-83-2 108-89-2 108-83-2 108-89-2 N/R 134-103 134-104 12R11090A 1-3/8 1-7/16 1-11/16 1-11/16 0.031 108-83-2 108-89-2 108-83-2 108-89-2 N/R 134-103 134-104 12R11090A 1-3/8 1-7/16 1-11/16 1-11/16 0.031 108-83-2 108-89-2 108-83-2 108-89-2 N/R 134-103S 134-104S 12R11090A 12R11090A EDIT It looks like this should work 34R11196AQ ![](/ubbthreads/images/graemlins/wave.gif)
[Re: pittsburghracer]
#1449017
06/07/13 10:46 PM
06/07/13 10:46 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Aftermarket Detailed Holley Carburetor Info Enter Holley Part No Part No Model CFM Renew Kit Trick Kit Needle And Seat Primary Jet Sec Jet or Plate Pri Metering Block Sec Metering Block Pri Power Valve Pri Nozzle Sec Nozzle or spring color Pri Bowl Gasket Pri Metering Block Gasket Sec Bowl Gasket Sec Metering Block Gasket Sec Metering Plate Gasket Primary Fuel Bowl Secondary Fuel Bowl Base Plate Pri Venturi Diameter Sec Venturi Diameter Pri throttle Bore Sec Throttle Bore Notes 0-4780 4150 800 37-485 37-933 6-504 122-72 122-76 N/S N/S "(12,21)" 0.031 0.031 108-83-2 108-89-2 108-83-2 108-89-2 N/R 134-103 134-104 N/S 1-3/8 1-7/16 1-11/16 1-11/16 0-4780-1 4150 800 37-485 37-933 6-504 122-70 122-76 N/S N/S "(12,21)" 0.031 0.031 108-83-2 108-89-2 108-83-2 108-89-2 N/R 134-103 134-104 N/S 1-3/8 1-7/16 1-11/16 1-11/16 0-4780-2 4150 800 37-485 37-933 6-504 122-70 122-85 N/S N/S 125-65 0.031 0.031 108-83-2 108-89-2 108-83-2 108-89-2 N/R 134-103 134-104 12R11090AP 1-3/8 1-7/16 1-11/16 1-11/16 0-4780-3 4150 800 37-485 37-933 6-504 122-71 122-85 34R11196AQ N/S 125-65 0.031 0.031 108-83-2 108-89-2 108-83-2 108-89-2 N/R 134-103 134-104 12R11090A 1-3/8 1-7/16 1-11/16 1-11/16 0-4780-4 4150 800 37-485 37-933 6-504 122-71 122-85 34R11196AQ N/S 125-65 0.031 0.031 108-83-2 108-89-2 108-83-2 108-89-2 N/R 134-103 134-104 12R11090A 1-3/8 1-7/16 1-11/16 1-11/16 0-4780-5 4150 800 37-485 37-933 6-504 122-71 122-85 34R11196APQ 34R11198APQ 125-65 0.031 0.031 108-83-2 108-89-2 108-83-2 108-89-2 N/R 134-103S 134-104S 12R11090AP 1-3/8 1-7/16 1-11/16 1-11/16 0-84780 4150 800 37-485 37-933 6-504 122-71 122-85 34R11196A N/S 125-65 0.031 0.031 108-83-2 108-89-2 108-8 http://www.carburetion.com/HolleyNumbers.asp
