Page 2 of 3 1 2 3
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445411
05/17/14 01:36 AM
05/17/14 01:36 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Good job; I have body and paint left on mine but you can see my progress here. https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: My 1980 D150 Big block swap [Re: Hemi_Ram] #1445412
05/18/14 11:29 AM
05/18/14 11:29 AM
Marysville, WA
77ProStreet Offline OP
Marysville, WA
Oh yeah, I've been keeping up on your build. Very nice!
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445413
05/18/14 11:16 PM
05/18/14 11:16 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Coming along nicely! I guess I need to get the scoop on brake boosters and BB's. I was eyeballing things recently and wondering if it was going to fit and you may have answered my question.
Re: My 1980 D150 Big block swap [Re: 70Duster440] #1445414
05/19/14 02:59 AM
05/19/14 02:59 AM
Marysville, WA
Marysville, WA
Its still close with tall valve cover. [image][/image]
Re: My 1980 D150 Big block swap [Re: 70Duster440] #1445415
05/31/14 03:51 AM
05/31/14 03:51 AM
Marysville, WA
Marysville, WA
A few more pics after POR 15. [image][/image] [image][/image] [image][/image]
Mustang gas tank is next. I was a little premature with my paint cause I have to relocate that x member and weld in brackets to hold gas tank. OH well
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445416
05/31/14 03:58 AM
05/31/14 03:58 AM
Marysville, WA
Marysville, WA
A month back I ordered 2 of these for the front 18x8. Just testing them on the back and making measurements. 20x10's are on order and should be here in a couple weeks. I know a couple of you guys run these, didn't realize they were the same till I got mine. [image][/image]
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445417
05/31/14 04:12 AM
05/31/14 04:12 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Needs a glass hood..
I am truckless..
Re: My 1980 D150 Big block swap [Re: 340SHORTY] #1445418
05/31/14 11:49 AM
05/31/14 11:49 AM
Huntsville, AL
V
venom107 Offline
venom107  Offline
V
Huntsville, AL
Are you running a spacer for the front wheels? I had to have the rotor hub turned down for the wheels to fit. I still have to modify the dust caps to get the center caps on.
Re: My 1980 D150 Big block swap [Re: venom107] #1445419
05/31/14 12:33 PM
05/31/14 12:33 PM
Marysville, WA
Marysville, WA
I haven't even tried them on the front yet. I'm sure I will be doing the same thing you did. I'll check it out today.
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445420
06/01/14 01:18 AM
06/01/14 01:18 AM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
so your gonna run an 18x8 20x10 combo too?
Re: My 1980 D150 Big block swap [Re: venom107] #1445421
06/05/14 04:28 AM
06/05/14 04:28 AM
Marysville, WA
Marysville, WA
I finally tried those wheels on the front. Looks like I will be getting my rotors turned down too. What a PITA! I tried a 1/4" spacer, but the more I thought about it....just not a good idea. I'll have to look into a stubby dust cover also, I think I've seen them around.
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445422
06/05/14 11:54 PM
06/05/14 11:54 PM
Huntsville, AL
V
venom107 Offline
venom107  Offline
V
Huntsville, AL
I'm out of town right now, but when I get back I will try to get a pic of what I had done.
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445423
06/11/14 08:09 PM
06/11/14 08:09 PM
Marysville, WA
Marysville, WA
I started on my mustang gas tank install, here's a couple pics. I went with the bigger '70 tank, 22 gallon I believe.
I took out the existing X member here: [image][/image]
..and flipped it over and welded it in the back. Now I have a built in mounting surface for the rear of the tank and I'll use some 1.5 or 2" L channel for the front. [image][/image]
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445424
06/11/14 10:19 PM
06/11/14 10:19 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
looking good. i'm almost motivated enough to go pull my engine, paint the bay, and drop the new one in....
*almost.
Re: My 1980 D150 Big block swap [Re: Golden-Arm] #1445425
06/12/14 10:12 AM
06/12/14 10:12 AM
scratchnfotraction Offline
Almost
Re: My 1980 D150 Big block swap [Re: scratchnfotraction] #1445426
06/13/14 01:29 AM
06/13/14 01:29 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I dont have a motor to pull..
I am truckless..
Re: My 1980 D150 Big block swap [Re: Golden-Arm] #1445427
06/13/14 04:18 PM
06/13/14 04:18 PM
Marysville, WA
Marysville, WA
*almost.
HA! Nice GoldenArm!
Sorry Larry.
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445428
06/13/14 09:28 PM
06/13/14 09:28 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Great timing! Getting ready to do the same thing using a Stang tank on ours. Interested to see what issues, if any, you encounter.
Re: My 1980 D150 Big block swap [Re: 340SHORTY] #1445429
06/13/14 10:36 PM
06/13/14 10:36 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i'm sure you'll find something to pull.....
Re: My 1980 D150 Big block swap [Re: Golden-Arm] #1445430
06/14/14 02:38 AM
06/14/14 02:38 AM
Marysville, WA
Marysville, WA
So far so good. It may take another week to get back on it, just found out my floor is rotten in my camp trailer it's a 2004 and that's the reason I bought it, newer = no problems, right!?! Now I have to gut the whole front half....PITA!!!!
Anyway I'll jump back on the tank and finish up with some pictures.
Page 2 of 3 1 2 3
