Re: Will a PCV help condensation in Alum. Blk.?
[Re: rickraw]
#1444258
08/09/13 10:27 PM
08/09/13 10:27 PM
Posts: 2,686 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I found the source, at least a big one, could be more. It is at the water passage on front # 2 cyl. and is leaking into the push rod passage. I thought that I had them sealed with "Right Stuff", but apparently not! I am pulling the engine to put new bearings in. No 1 rod looked fine, No. 8 shows signs of antifreeze. I cannot risk a failure. I thought the Cometics were the ones to use? I may have the early set that didn't seal the water passages well on World blocks. Were there any other problems you know of with them?
Thanks, Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
