weird 8_3/4 question
#14441
02/17/05 03:09 PM
02/17/05 03:09 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Hey all, I have a weird question. I just pulled the 2.76 geared center section out of the 8_3/4 in my challenger to put in a new 3.23 posi unit. When I pulled the old unit out there was a peice of 1x1 inch by 3 inches long square steel in between the differential gears?!?!?!? See attatched picture? I'm assuming it means that whoever put this thing in at some point didn't have the correct parts to hold it together so they just threw the steel in there to keep the gears from folling out? Anyway I'm just curious if anyone knows why it really might be there? The weird thing is the thing worked perfectly for me for well over 50,000 miles since I bought it in 96.. Also does this mean the diff is scrap, or can I still sell it?
Thanks, -Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
Re: weird 8_3/4 question
[Re: blown340]
#14442
02/17/05 03:19 PM
02/17/05 03:19 PM
Posts: 1,323 La Grange, Ky
70rrclone
La Grange, Ky
Is that piece welded in there if so it may be an attempt to weld the spider gears together to make a posi out of it. It would definately hurt resale.
IIRC there shouldnt be anything other than the spider gear pin in that area
shane
can you get a better pic of the metal and the spider gear area??
[Re: blown340]
#14444
02/17/05 03:29 PM
02/17/05 03:29 PM
Posts: 5,118 Alone in the darkness
gamagoat6x6
super street
super street
You would need shorter axles with that piece in there. Normally the axles touch the center pin and you might have problems installing your new 3:23 posi unless you use green bearings. `66 monaco 500 `64 galaxie 500XL
`02 RAM2500 SPORT V10 4x4
`06 GMC sierra
NO cars
[Re: 70rrclone]
#14445
02/17/05 03:33 PM
02/17/05 03:33 PM
blown340
Walnut Creek, CA
Nope, its just sitting in their loosely. It'll be a while before I can grab a new picture of it but here's a cropped and enlarged closeup.
-Jon
[Re: gamagoat6x6]
#14446
02/17/05 03:35 PM
02/17/05 03:35 PM
gamagoat6x6
super street
super street
I think some ingenious guy used that instead of the thrust block. `66 monaco 500 `64 galaxie 500XL
`06 GMC sierra
NO cars
[Re: blown340]
#14448
02/17/05 03:53 PM
02/17/05 03:53 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The square thrust block pictured is factory original and correct for pre-'64 rear ends.
Prior to '64 the center thrust block width was different for Sure-Grip and non Sure-Grip differentials; the square thrust block was about 1/4" thinner than the Sure-Grip buttons and needed a longer axle. Starting in '64 they decided to make the axles the same length and introduced the wider round thrust block for the non Sure-Grip units.
[Re: John_Kunkel]
#14452
02/17/05 06:30 PM
02/17/05 06:30 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
John, you are the man. Learn something new every day on Moparts. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: Mr_fixit]
#14455
02/18/05 06:11 PM
02/18/05 06:11 PM
John_Kunkel
Rio Linda, CA
There's no guarantee that there would be enough adjustment available to take up 1/4" of play even with two adjusters.
The axle end play spec has remained pretty much the same over the years, but the pre-'65 adjustment was done with shims.
