Re: Why does the air pressure in my tires keep increasing? [Re: Dodgem] #1443714
05/29/13 08:38 PM
05/29/13 08:38 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I am thinking somebody knows you check the pressure every 3 weeks or so and thinks you might as well have a reason to.
I have mechanical Aptitude.
I can screw up anything.
Re: Why does the air pressure in my tires keep increasing? [Re: Dodgem] #1443715
05/31/13 01:23 PM
05/31/13 01:23 PM
Des Moines IA
Soopernaut Offline OP
Des Moines IA
Is you garage a constant 32 degrees or has it been warming up with the warmer weather?
My garage has been warming up but it has been warming up other years too without this phenomenon occurring.
I guarantee it isn't another person doing it.
That leaves something mechanical like brakes or my gauge is reading inaccurate. I don't see why the gauge would read differently on 2 of the tires unless the others are actually low and reading normally.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Why does the air pressure in my tires keep increasing? [Re: Soopernaut] #1443716
05/31/13 01:27 PM
05/31/13 01:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The only thing I can think of, is those tires exploding if you don't stay on top of it. Tires cost too much to just let them over inflate until they blow!
Re: Why does the air pressure in my tires keep increasing? [Re: Soopernaut] #1443717
05/31/13 02:58 PM
05/31/13 02:58 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Tire pressures increase as temps increase as the air expands. Now short of a faulty gauge a nitrogen filled tire will not increase or decrease in pressure as much as a tire filled with regular air!
Re: Why does the air pressure in my tires keep increasing? [Re: Dodgem] #1443718
06/01/13 09:38 AM
06/01/13 09:38 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
how much are you talking about?
Re: Why does the air pressure in my tires keep increasing? [Re: bonefish] #1443719
06/01/13 11:30 AM
06/01/13 11:30 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Maybe try letting one go and see how far it will increase. To me this should be impossible. Tires just don't increase pressure for no reason. The air isn't going to leak into a tire. Any way for air to travel through the tire will let air out not in. Gotta be some kind of bad joke.
Re: Why does the air pressure in my tires keep increasing? [Re: Dodgem] #1443720
06/01/13 11:40 AM
06/01/13 11:40 AM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
I love how people pay for nitrogen filled tires. FYI our "regular air" is 78% nitrogen.
Re: Why does the air pressure in my tires keep increasing? [Re: teflon] #1443721
06/01/13 03:08 PM
06/01/13 03:08 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
It's the 21% Oxygen that expands and contracts like crazy!
Re: Why does the air pressure in my tires keep increasing? [Re: Soopernaut] #1443722
06/01/13 07:28 PM
06/01/13 07:28 PM
Here
jcc Offline
jcc  Offline
Here
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: Why does the air pressure in my tires keep increasing? [Re: jcc] #1443723
06/01/13 07:45 PM
06/01/13 07:45 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Why does the air pressure in my tires keep increasing? [Re: hemi71x] #1443724
06/02/13 08:51 AM
06/02/13 08:51 AM
Australia
charger RTSE Offline
Australia
The tire must be getting hotter, do you have in floor heating where you park your car.
Re: Why does the air pressure in my tires keep increasing? [Re: charger RTSE] #1443725
06/02/13 07:46 PM
06/02/13 07:46 PM
Des Moines IA
Des Moines IA
No.
