Re: TCI aluminum deep pan leaking - Part 2
[Re: hp383]
#1442552
05/28/13 01:43 AM
05/28/13 01:43 AM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Come on??? Do pan bolts really come loose or does the gasket shrink and the bolts need tightening? I would tighten and paint mark them and drive it. My bets are junk gaskets or a leak from somewhere else.
Thats what I was wondering. As the gasket compresses, then seats, it will cause the bolts to loosen up.
They do the same thing on valve cover gaskets, and hose clamps.
If I knew the answer I'd not ask the question.
I know for a fact that when changing trans fluid using the stock steel pan this doesn't happen. But with this aluminum pan the bolts need re-torquing every time I get home from taking the car out and about.
There's nothing leaking from the transmission, only from the gasket area when the bolts loosen up. I'm not making this stuff up. I'm frustrated and sick of messing with it. I'm about ready to go back to a steel pan.
BTW, it's a Fel-pro gasket.
[Re: NITROUSN]
#1442555
05/28/13 11:19 AM
05/28/13 11:19 AM
Junky
Wherever I am.
Go to a Mopar dealer and get a factory gasket.
Is this factory gasket going to work on a non factory aluminum pan?
[Re: scratchnfotraction]
#1442559
05/29/13 07:56 PM
05/29/13 07:56 PM
Junky
Wherever I am.
remember....longer bolts and do not over torque them.
that gasket will not compress. just that o-ring bead compresses.
Thanks, Scratchn.
[Re: gpuller]
#1442560
05/29/13 07:57 PM
05/29/13 07:57 PM
Junky
Wherever I am.
That gasket is the cats ass, wont smash from over tightening. Use some new bolts and lock washers. When I posted that price that was from a few years ago. Figured it had to go up in price some.
I figured so. I posted it just in case someone wanted to know.
[Re: Junky]
#1442561
05/29/13 08:12 PM
05/29/13 08:12 PM
Posts: 5,349 Planet Earth
RoadRunnerLuva
Planet Earth
On my Duster...I have a M.P. STEEL deep pan with the factory rigid gasket that the dealers sell. No more leaks from the pan... Shift shaft seal, that's next on the to do list! ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
Plymouth Makes It!
