1970 E Body Broadcast Sheet Gurus #1441971
05/25/13 10:41 PM
05/25/13 10:41 PM
Chicago Blackhawks
hemicar1971 Offline OP
Chicago Blackhawks
All you guys that collect 1970 E Body information, have you ever seen a broadcast sheet with a date the does not exist. What I am asking is a date such as on the 31st of a month that does not have a 31st in the month. Would it be possible to have: example B31 on a broadcast sheet or on a Fender Tag. Also have you ever seen a date that differs from the Fender Tag to the Broadcast Sheet on the same car such as the above example B31 on one and C01 on the other.
1971 HEMI E BODY REGISTRY
Re: 1970 E Body Broadcast Sheet Gurus [Re: hemicar1971] #1441972
05/25/13 10:50 PM
05/25/13 10:50 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
931 dates are common on fender tags & broadcast sheets for 1970 Hamtramck cars as one example. They are a great argument for the folks that think it is the actual 'build date'. It just did not happen that way.......
