Octane for 5.7 Hemi *DELETED* #1440685
05/22/13 10:46 PM
05/22/13 10:46 PM
Warrenton, VA
RoadRunnerJD Offline OP
Warrenton, VA
Post deleted by RoadRunnerJD
Re: Octane for 5.7 Hemi [Re: RoadRunnerJD] #1440686
05/22/13 11:04 PM
05/22/13 11:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Not really.
Re: Octane for 5.7 Hemi [Re: RoadRunnerJD] #1440687
05/22/13 11:36 PM
05/22/13 11:36 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Usually no. What year? What application (Ram,300,etc?)
Re: Octane for 5.7 Hemi [Re: Dcuda69] #1440688
05/22/13 11:37 PM
05/22/13 11:37 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
You should run what it tells you to in the owner's manual.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Octane for 5.7 Hemi [Re: Dcuda69] #1440689
05/22/13 11:41 PM
05/22/13 11:41 PM
Warrenton, VA
Warrenton, VA
It's a 2013 Charger R/T Daytona
Re: Octane for 5.7 Hemi [Re: RoadRunnerJD] #1440690
05/22/13 11:44 PM
05/22/13 11:44 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Then run what they tell ya...unless of course you have extra money
Re: Octane for 5.7 Hemi *DELETED* [Re: RoadRunnerJD] #1440691
05/23/13 12:00 AM
05/23/13 12:00 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: Octane for 5.7 Hemi *DELETED* [Re: OzHemi] #1440692
05/23/13 01:05 AM
05/23/13 01:05 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
exactly. way to help the next guy, when he has the same question.
Re: Octane for 5.7 Hemi *DELETED* [Re: OzHemi] #1440693
05/23/13 01:06 AM
05/23/13 01:06 AM
Warrenton, VA
Warrenton, VA
The question was is their any good reason to run high test if it just calls for regular? Would you get any better performance? Would it be better or worse for the plugs and injectors? Just wondering if it would make any significant difference?
Re: Octane for 5.7 Hemi *DELETED* [Re: RoadRunnerJD] #1440694
05/23/13 01:23 AM
05/23/13 01:23 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
There is some belief in the theory that once a fuel is selected that allows the engine to run without detonation, using a fuel with higher octane actually results in a power reduction. The reason? The anti-knock compounds in higher octane fuel result in a slight loss of energy content.
Re: Octane for 5.7 Hemi *DELETED* [Re: RoadRunnerJD] #1440695
05/23/13 02:35 AM
05/23/13 02:35 AM
IN
ahy Offline
ahy  Offline
IN
I've always run recommended 89 for normal driving and high test when towing. Why? Sustained heavy load (pulling a long hill with heavy trailer) builds heat and can cause detonation. The knock sensor may prevent engine damage by pulling timing... but cuts power when its needed most. Reduced timing also hurts mileage. That's why I run the high test when towing.
Re: Octane for 5.7 Hemi *DELETED* [Re: RoadRunnerJD] #1440696
05/24/13 07:28 AM
05/24/13 07:28 AM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
You are AWESOME! Great job by you. Hey, look...the post is still here. Maybe you didn't do such a good job after all.
Earning every penny of that moderator paycheck.
DBAP
Re: Octane for 5.7 Hemi *DELETED* [Re: RoadRunnerJD] #1440697
05/24/13 08:16 AM
05/24/13 08:16 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
