Anybody have a rocker nut constantly back off? #1438522
05/18/13 09:13 PM
05/18/13 09:13 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
If so, post what problems you found please. We have one that's giving us fits. Thanks!
Adriel Paradise
Substation Design Engineer III
Re: Anybody have a rocker nut constantly back off? [Re: Adrielp] #1438523
05/18/13 09:30 PM
05/18/13 09:30 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What rocker arm ?
Re: Anybody have a rocker nut constantly back off? [Re: Adrielp] #1438524
05/18/13 09:39 PM
05/18/13 09:39 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Check spring on that rocker.
Re: Anybody have a rocker nut constantly back off? [Re: JohnRR] #1438525
05/18/13 09:42 PM
05/18/13 09:42 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Ball on the adjuster or cup?
How far are you screwing the adjuster through the rocker arm to get your lash?
There is a reason I ask these questions. Many times guys have too short a pushrod. This requires the adjuster to be screwed so far out of the rocker arm that you start to get defection in the adjuster. This deflection causes the nut to get loose. Just maybe that particular rocker requires a little more of the adjuster poking out than the others.
Leon
Re: Anybody have a rocker nut constantly back off? [Re: Leon441] #1438526
05/18/13 09:46 PM
05/18/13 09:46 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
is the rocker arm aluminium? if so have you had a valve/piston contact with that arm? if so change the rocker arm.
Re: Anybody have a rocker nut constantly back off? [Re: rebel] #1438527
05/18/13 11:17 PM
05/18/13 11:17 PM
IN
ahy Offline
ahy  Offline
IN
Check that the nut contacts the arm evenly all the way around. If the face of the rocker isn't square where the nut lands, it will back off.
Re: Anybody have a rocker nut constantly back off? [Re: ahy] #1438528
05/18/13 11:39 PM
05/18/13 11:39 PM
JohnRR Offline
JohnRR  Offline
Re: Anybody have a rocker nut constantly back off? [Re: Adrielp] #1438529
05/18/13 11:51 PM
05/18/13 11:51 PM
Time to change the adjsuters and lock nuts
Re: Anybody have a rocker nut constantly back off? [Re: Cab_Burge] #1438530
05/19/13 01:03 AM
05/19/13 01:03 AM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
After some discussion, we believe the threaded hole maybe out of round and works its way loose at high rpm. This rocker had previous damage due to a pushrod coming loose but we were given the okay to run the rocker by the manufacturer(Harland sharp). Anyway we are replacing the rocker this week.
Adriel Paradise
Re: Anybody have a rocker nut constantly back off? [Re: Adrielp] #1438531
05/19/13 01:12 AM
05/19/13 01:12 AM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
check your lifter,ours was doing that & it was the lifter wearing out inside the cup
